Author Topic: Center Stand Pivot Bolt  (Read 6351 times)
Offline pallum
« on: August 27, 2011, 10:28:36 PM »
Recently noticed this bolt on my K75:
This is looking at the center stand from below the transmission, bolt is on port side.
At the right end is a nut, and at the left is the head of the bolt, circular and completely rounded. The nut seems very set in place as I can't tighten or loosen it by hand, but there's no real way I see to put a wrench to it since there's no way to hold onto the bolt head  :P  Am I missing something? Or is it ok for the nut to not be fully tightened to the stand's mounting bracket?
  • Federal Way, WA
Re: Center Stand Pivot Bolt
« Reply #1 on: August 28, 2011, 08:32:37 AM »
This is a non genuine bolt, it should be a M10x50 countersunk with allen head.
The genuine bolt is shorter and ends ~flush on the inside of the bracket.
And it should be secured with Loctite 243.
Inge K.
Offline pallum
« Reply #2 on: August 29, 2011, 12:49:18 AM »
Well that answers that  :P It's hard to tell what's supposed to be there from part diagrams, will look into it
  • Federal Way, WA
« Reply #3 on: August 29, 2011, 04:48:44 AM »
Then it`s time to change the source for the part diagrams, try this.
Inge K.
