Author Topic: K1 starting/blinker/light issues  (Read 3874 times)
Offline Euro Spec
« on: October 04, 2016, 01:04:29 AM »
Hey guys I've got an intermittent problem with my new-to-me K1 that I brought back from Germany this summer.
Symptoms:
Occasionally when I go to start the bike I hit the start button and I get a single audible "click" but no turnover of the engine.  When this happens, my blinkers, headlight, and horn do not work.  Sometimes if I move the bike around then it will suddenly work again and start up.  When it starts up I have the following issues:
Headlight will not illuminate unless I rev the engine about 3000 rpms.  Blinkers will either 1) not work 2) flash once or 3) both blinkers will flash simultaneously once.
Once I ride the bike around for a minute or two all symptoms go away and everything works fine.  But if I turn off the bike, there is about a 20% chance all the symptoms will come back.
The bike has a brand new battery and it did this with the old battery as well.  Most of the time it starts up fine and runs with no issues.  I would guess it's a starter issue except for all of the associated electrical issues with the lights/blinkers/horn.
Thoughts?  Thanks for the help.
PS--I just moved back to the America and already did a round trip from Seattle to Montana and back with my RS and had a blast! Time for an oil change and new tires.
  • Pacific NW
  • 1990 K100RS 16V, 1990 K1
Re: K1 starting/blinker/light issues
« Reply #1 on: October 04, 2016, 07:21:15 AM »
There is a connection between incipient starter failure and other electrical equipment malfunction. Here's a post for you that could be informative. There are also many posts on MOTOBRICK.COM that would be useful, too.
Offline Euro Spec
« Reply #2 on: October 04, 2016, 09:13:21 AM »
Shoot, then it could be the starter. Maybe that's why it suddenly works after I move the bike around, I'm getting carbon off the brushes.  Does that explain why I get light and blinker functionality only after the engine has been revved?
  • Pacific NW
Offline Inge K.
« Reply #3 on: October 04, 2016, 10:59:24 AM »
Then it is the starter,.....quite common problem.
  • Norway
Offline Euro Spec
« Reply #4 on: October 04, 2016, 11:30:53 AM »
And when I put the battery in last week I told me wife, "See that there?  That's the starter, I want to clean that at some point."  And I should have just done it then.   Whoops.
  • Pacific NW
