Author Topic: Fork Seals  (Read 7530 times)
Offline motorheadsdiygarage
  • Knowledge is Power
Fork Seals
« on: October 01, 2016, 10:49:51 AM »
I have to replace my fork seals soon. Leaking on the LH side.
Would like to know what seals you use OEM or AFTERMARKET?
Also would like to add gaiters/boots when they're assembled.
Are there any good sources out there?
I'm near Montreal, Canada.
  • Near Montreal Canada
  • 1992 BMW K75S
Re: Fork Seals
« Reply #1 on: October 01, 2016, 10:55:15 AM »
I use OEM seals and Rancho 1952 boots. Cut off the lower severed portion of the boot along a pleat to get a snug fit and pristine look. :hehehe
Re: Fork Seals
« Reply #2 on: October 01, 2016, 10:56:50 AM »
+1 on the Rancho 1952 boots.  I have them on all three of my bricks.
Re: Fork Seals
« Reply #3 on: October 01, 2016, 04:05:08 PM »
Thanks Laitch, I ordered the Rancho 1952 boots today. Rancho 1952 boots
Would you suggest to order all the "O-rings" as well as the teflon sliders?
  • 1992 BMW K75S
Re: Fork Seals
« Reply #4 on: October 01, 2016, 05:49:56 PM »
Not sure how far you intend on dismantling your forks, but it might be worth your time to inspect the brass slider bushings. If they start having excess wear, your seals can leak easier.
1995 K1100LT 0302044 (R.I.P)
Re: Fork Seals
« Reply #5 on: October 02, 2016, 10:57:09 AM »
Search on "fork seal cleaner".  It's a little thingy that pulls the dirt out of your fork seals without having to disassemble them.  You might just have some dirt in the seals.
Offline F14CRAZY
Re: Fork Seals
« Reply #6 on: October 02, 2016, 12:23:41 PM »
Seal Mate. The local non-BMW powersports dealer has them or you can get them online from various places (I'd use ebay).
Most fork seals aren't bad, they just have dirt and dust and bug guts in them. Seal Mate helps to pick that stuff out. My fork seals were leaking a while back and replacement of the seals wasn't necessary. I just used the Seal Mate then changed my fork oil.
  • Grand Rapids, MI
  • '87 K75C
Re: Fork Seals
« Reply #7 on: October 02, 2016, 12:48:19 PM »
Looks like that is worth a try. I think I can make one out of a lexan bottle or some suitably thin plastic. Thanks  :2thumbup:
That will save me the money to maybe put towards a clutch disc or tires. :riding:
  • 1992 BMW K75S
Re: Fork Seals
« Reply #8 on: October 03, 2016, 06:23:54 PM »
The "DIY Tool" looks like it did the trick boys. :2thumbup:
Thanks to all who chimed in.  :k75s :beer:
  • 1992 BMW K75S
Offline F14CRAZY
Re: Fork Seals
« Reply #9 on: October 03, 2016, 08:52:16 PM »
Yea I forgot to mention that others like johnny have made their own Seal Mates which work well. I was going to make my own but the local non-BMW dealer had them on the shelf so I figured I might as well spend the few bucks.
If you haven't changed your fork oil yet or in a while it might be good too. Handling and ride always seems better after. Might run your "Seal Mate" tool another time or two just to be sure.
I personally forget to pump the forks in between pickings but I could see that being a good thing to do.
  • Grand Rapids, MI
  • '87 K75C
Re: Fork Seals
« Reply #10 on: October 07, 2016, 06:50:37 PM »
Four more rides and no leakage.....  :clap:
  • 1992 BMW K75S
