Author Topic: Notchy throttle  (Read 4081 times)
Notchy throttle
« on: September 28, 2016, 09:35:00 AM »
I'm putting this topic here for informational purposes since it's solved.
When assembling my 1995/1994 Frankenbike (http://www.motobrick.com/index.php/topic,8569.msg65996.html#msg65996) I figured I'd just swap out the heated grips from the retired 1995 and put them on the 1994. So I put the heated grips from the 1995 on the 1994, using the 1994's original grip assembly, throttle cam and throttle assembly cap. When I got them on, the throttle was notchy -- obviously something was funky with the cam in the throttle grip assembly or with the gears in the grip.
I spent the good part of a day taking it apart and putting it back together again before giving up and calling my buddy Mike B who was a BMW mechanic back in the 1990's. Mike informed me that I needed use the entire assembly from one bike or another, i.e. grip, cam and cap. You can't mix-n-match them.
I don't know how this is possible -- there is only one number per part listed on the fiche. All I know is using the entire assembly, i.e. #8, #10, #5 (tube, not including rubber covering), and #9, did the notchiness go away. I tried using just the 1995 cam and cap in the 1994 housing, no dice. It was all or nothing, or should I say, all or notching.
Like I said, I don't know why, all I know is that it was an unexpected, undocumented PITA that I hope noone else has to deal with.
Re: Notchy throttle
« Reply #1 on: September 28, 2016, 09:52:17 AM »
This mod was done to reduce the throttle twist motion.
Re: Notchy throttle
« Reply #2 on: September 28, 2016, 10:02:32 AM »
So this mod was made in 1995, the last K75 production year? And if you want to replace any one of these parts with a part that's listed in the fiche, you have to replace the entire assembly?
That's kind of bizarre.
Re: Notchy throttle
« Reply #3 on: September 28, 2016, 10:37:32 AM »
#5, 8, 9 is matched parts for this mod, #10 should be unchanged in design.
