Author Topic: K100 engine and drivetrain  (Read 5289 times)
Offline zipster68
« on: September 23, 2016, 04:01:39 PM »
Kind of a newbie question.  Is the represented drawing of K75 engine and drivetrain the same as K100 in concept?  See pic.
Cheers,
Ray
  • Ferndale, Michigan
  • 1986 K100RS, 1977 naked Goldwing, 1975 Yamaha RD350 smoker, 1978 Vespa P200, 1980 Lambretta Jet 200
Re: K100 engine and drivetrain
« Reply #1 on: September 23, 2016, 04:05:14 PM »
 :2thumbup:
« Reply #2 on: September 23, 2016, 04:11:25 PM »
Yes. Transmission→driveshaft→final drive.
Offline zipster68
« Reply #3 on: September 23, 2016, 05:54:24 PM »
Same clutch location, similar sealing types?
-Ray
« Reply #4 on: September 23, 2016, 06:19:00 PM »
Different clutch diameters, and different final drive ratio's. But you can swap between models. Final drive ratios are stamped into the housing just in front of the shock absorber. You can even put a later Para Lever onto the early ones with a bit of modification, the conversion is posted in the library as is all the final drive ratios. Manuals can also be found in the library.
