Author Topic: Load Shed Relay Replaced1987 K75s - Headlight stays on with ignition off?  (Read 20711 times)
Offline Rcgreaves
I arrive at work before dawn-i turn off the bike and the headlight stays illuminated... it would be a nice feature to illuminate my walkway to the door but the battery would have been dead before lunch.  So I disconnected the battery..
What should I troubleshoot?
Sign me:  Love my Brick.
Doing “better than I deserve"
Re: 1987 K75s - Headlight stays on with ignition off?
« Reply #1 on: September 15, 2016, 09:37:16 PM »
My guess is the ignition switch.
Offline Rcgreaves
« Reply #2 on: September 18, 2016, 11:40:49 AM »
new oem ignition switch/key set ordered from ECS tuning Ohio $87 shipped. thanks Laitch.  Wondering what happens to the switch to do this.. ie is it electronic or mechanical? would it clean up?
« Reply #3 on: September 18, 2016, 11:55:30 AM »
A problem with the ignition switch won't end up with the headlight permanent on, but the parking light.
My guess is that some PO have mounted relays in the headlight circuit, and the contacts have welded.
That is if only the headlight stays on and nothing else.
Offline Rcgreaves
« Reply #4 on: September 18, 2016, 12:04:44 PM »
so is the parking light you reference when the tail light remains illuminated? Or, is this something on the gauge with which im unfamiliar?
What relay? I'll go restudy the wiring diagram...
« Reply #5 on: September 18, 2016, 12:14:13 PM »
Yes the taillight is in the same circuit as the parking light.........I have replied on the PM.
Offline Rcgreaves
« Reply #6 on: September 20, 2016, 08:01:24 PM »
So I've been studying the start service manual looking for clues as to why this headlight would stay on. What about the power shedding relay? Does the headlight run through that? I know on my Hondas there are there are switches to interrupt power to the headlight when you operate the starter. All the discussion about the parking light seems confusing and tertiary. It's the headlight!
« Reply #7 on: September 20, 2016, 10:59:29 PM »
The reason the link for ignition switch disassembly was provided in my answer to your first post was to aid in cleaning up the switch. My answer was a guess at the cause and cleanup would be a relatively easy way and inexpensive way to rule out that as the cause.
The load (power) shedding relay diverts current from the headlight during start up.
I believe that Inge is trying to determine exactly what is happening with your bike by describing symptoms and causes. The parking light—a small bulb in the headlight assembly—and the tail light are in the same circuit—they light together when their switch is activated. If the tail light is not lit and it is the headlight, not the parking light, that is lit, then from his extensive experience, he is positing that fused relay contacts in a circuit are a more likely cause of the symptom.
Hunting the source of electrical dysfunction takes patience. You might need to lift the tank, open the relay box and compare what is in there with diagrams on the site to determine if that's where a failure is likely. Sometimes just knocking the relay with a screwdriver handle will free a stuck contact. If that happens, that relay should be replaced. Otherwise, it will be more complicated.
Posting photos of what you encounter might help others identify a whacked assembly.
Offline Rcgreaves
« Reply #8 on: October 10, 2016, 10:19:11 PM »
Offline Rcgreaves
« Reply #9 on: October 10, 2016, 10:33:22 PM »
Tonight I installed a replacement starter switch- a nice improvement over the original but not a solution to the headlight problem . Next I will clean the ignition switch.
Offline Rcgreaves
« Reply #10 on: October 11, 2016, 06:14:31 AM »
This morning at zero dark 30 and on my way to work I took a moment to tap relays and sure enough when I tap this one the headlight went off so I'll replace it with new it's a five prong job14595743 date of manufacture stamped on the case is one of 87 it's had a good service life!
« Reply #11 on: October 11, 2016, 07:37:11 AM »
Looks like some PO have buyed a OEM fuel injection relay and used it as a headlight relay.
Unless this relay is mounted in the front left corner of the relay Box, because then it is the
fuel injection relay....and it's just a coincidence that your headlight did go out as it's different circuits.
Then it must be something close by this relay.
Offline Rcgreaves
« Reply #12 on: October 11, 2016, 04:45:42 PM »
So this relay is definitely in the front left position in the box. So does  that number correspond with a fuel injection relay? How odd? Now  if I understand your comment correctly and you guesstimated that a previous owner installed a headlight relay ? but I don't see a headlight relay in the wiring diagram -and this plug doesn't seem like something that was added on by an owner.  Sign me somewhat confused
Offline Rcgreaves
« Reply #13 on: October 11, 2016, 05:27:50 PM »
« Reply #14 on: October 11, 2016, 06:36:21 PM »
This needs to get unsnarled. I'll give it a try.
The number and location of the relay indicates that it's a fuel injection (FI) relay. Inge asserts that in his post. If the relay had not been in that position then it could possibly have been a FI relay used as a headlight relay. We can now rule that out because of its location. If you purchased another relay, you now have a spare FI relay.
Photos often help convey situations and aid diagnosis.
A headlight relay is not in your wiring diagram because they were not stock equipment on your bike. Read the pdf link of this post to learn why some owners install headlight relays.
What is being postulated is that your headlight's shutting off was coincidental to your tapping that relay but a connection problem might be close by and was affected by the vibrations from that tapping.
Does the headlight work correctly now?
Offline Rcgreaves
« Reply #15 on: October 11, 2016, 06:40:01 PM »
I have yet to buy any parts - yes headlight operated normally after a tap on FI relay
« Reply #16 on: October 11, 2016, 06:45:36 PM »
Really strange this, as this is to completly different circuits....only advice would be to carefully inspect
the relay box (especially the area close to the injection relay socket) and under the fuel tank for wires,
tap in connectors or relays that doesn't look oem.
If I have understand it correct....when you turn of the ignition, the headlight still stays on and absolutly
all other electric componts goes off and stays off?
Offline Rcgreaves
« Reply #17 on: October 11, 2016, 06:47:35 PM »
Offline Rcgreaves
« Reply #18 on: October 11, 2016, 06:49:32 PM »
Yes you understood me correctly. I will take some time this evening to scrutinize the harness and look for oddball or non-OEM items. PS-thanks for the headlight PDF SW I W my headlight wiring looks OEM any wimpy
Offline Rcgreaves
« Reply #19 on: October 12, 2016, 09:34:21 PM »
All
Again gentlemen I'm very appreicative of your patient assistance on this problem.
So I traced my relays according to the wiring diagram in my service manual.  There are no non-oem installations to by found by a PO such as a headlight relay.  The next relay to the right is the load shed relay so my hypothetical is that my rap on the FI relay tripped that trigger perhaps.  At the moment everything, the headlight and parking lights systems are performing normally so my thought is to at mimimum order a new load shed relay as that's related to the headlight. Yes?
To that end I looked up the 4 pole relay # 61 31 1375474 and discovered that this 4 pole relay isn't the same as what was listed it had 5 prongs..."odd".... MAX BMWs fiche lists a "mini relay" made by Tyco that has the correct prongs but they don't call it a load shed. Can anyone --- shed --- any light on this   :hehehe  for good measure I cleaned all the contacts and reassembled everything and it functions normally.
Offline Rcgreaves
« Reply #20 on: October 12, 2016, 09:55:16 PM »
So the Fiche says my load shed relay in a 1987 75s should be a 61311373585  NOT the 61311375474  hmmm ..
I need advice, perhaps this relay does the same job?
Offline Rcgreaves
« Reply #21 on: October 12, 2016, 10:02:35 PM »
so the 585 relay is superseded by the 588 by Tyco pictured... I don't know for certain if my load shed relay is the culprit here but I just can't see reassembling the fairing etc only to have the headlight glitch later. Opinions?   Max BMW offers the 588 for $36 + 8$
Thanks in advance.  swapping the FI relay makes no sense and changing out nothing makes no sense eit her
« Reply #22 on: October 13, 2016, 12:48:21 AM »
I think you've done some good work here. You haven't bought any parts. You isolated one location of the problem. You took action—knocking on things, which is a time-honored repair method—that corrected the problem, then you disassembled components in the area, inspected them, cleaned them and reassembled them. The result was that correct headlight function was restored.
It's still uncertain what caused the problem, so buying something to fix it doesn't quite follow either. At Euro Motoelectrics, the part number from MAX is referred to as a sub for the part number you're questioning on the existing relay. If it's comforting to have a spare relay, or to switch out the present one for one with the number in the fiche, buy it. What might be more useful in the long run is to be comfortable with disassembly when it's needed. Otherwise, purchasing a late model or new bike would be the way to go.
Inspecting and cleaning switches, connectors and the starter should be on any K-bike owner's program. The starter can be the cause of many interesting symptoms.
If the bike is operating correctly now, enjoy it.   :yes
« Reply #23 on: October 13, 2016, 02:49:01 AM »
Nice that you did find what caused it, the LSR probably had welded shut its contacts.
It's also other this and that which is powered by the LSR (horn, flashlight, fan) but all others needs to
be switched on to see it.
You can swap it With the horn relay (beside) which is identical.
The relays can be opened and the contacts checked, eventually dressed With some fine emery paper
be shure to blow off all dust before putting the housing back on.
Offline Rcgreaves
« Reply #24 on: October 13, 2016, 06:30:33 PM »
Thanks again gentlemen for the thoughtful replies. Laitch made the observation that I ought to be comfortable with disassembly if I want to ride a K bike... how true!  The more I wrench this bike to more I love the design.
