Author Topic: bump stop on shock  (Read 3015 times)
Offline Jerh Heffernan
bump stop on shock
« on: September 08, 2016, 06:35:00 PM »
Bust my Nivomat on a manhole last week. got a replacement used BMW shock today, fitted it and took it for a test drive, after returning i noticed the bump stop in the top of the shock had started to break up. i removed what was left of it, and took another test ride, the bike handles great and great suspension. do I need the bump stop? can i open that shock and fit a new stopper? I'd hate having to go to the bother of having to return it to the UK and wait for a new one. if its safe to ride without the stopper I'm fine with that, but would appreciate comments and advice.
  • Ireland
  • K100lt 1992
Offline PaulP
Re: bump stop on shock
« Reply #1 on: September 08, 2016, 07:02:16 PM »
My bump stop was at the bottom of the shock, but it had degraded beyond servicable use, so I chiselled it outta there.
I don't believe it will make much difference, it depends how much in the way of 'beans' you intend to give the machine.
  • Scotland, UK.
  • '91 K100 LT. Ex-Polizei.
« Reply #2 on: September 08, 2016, 07:08:41 PM »
I wouldn't be a hard driver by no means. 70-80 max. nearly all the time solo. I take it the bump is there to stop the shock bottoming out too harsh, rearly happens to me. the spring and damper are in great shape.
  • Ireland
  • K100lt 1992
« Reply #3 on: September 08, 2016, 09:16:27 PM »
If you don't use it for Moto-X or hit large holes or kerbs at speed you should be right. At a pinch you can get one from a shock specialist cut it at a angle and hold it in place with a stainless cable tie.
