Author Topic: Angle Iron for M/C lift  (Read 5152 times)
Offline White Dog
« on: August 29, 2016, 11:06:59 PM »
Numerous posts here on various ways to lift a K model but I don't see where the angle iron would be attached to the left side of the cycle.  Does anyone have a pic they can post?  I want to use my HF motorcycle jack to work on my K75.
  • Basement Garage
  • '95 K75 ABS.
'95 K75 ABS Red
'96 R1100RT Burnt Orange
2008 Goldwing Black
2014 CB1100 Std. Black
Reside in NC
Re: Angle Iron for M/C lift
« Reply #1 on: August 29, 2016, 11:22:08 PM »
Offline White Dog
« Reply #2 on: August 30, 2016, 09:49:48 AM »
From the looks of the engine and angle iron, I can readily see the right hand side of the engine, shown on the left pic.  The pic on the right appears to show the engine turned 90° to the right.  My question is "where does the angle iron attach to the left side of the engine--or, is it not necessary to have angle iron bolted on the left side of the cycle?
To my point, see the attached pic of the left side of my K75 engine.[/URL][/img]
  • Basement Garage
  • '95 K75 ABS.
'95 K75 ABS Red
2008 Goldwing Black
Reside in NC
« Reply #3 on: August 30, 2016, 06:55:50 PM »
As with the right side, the left side angle iron mounts to the two M8 holes provided on the oil pan to mount the lower fairing.
The oil pan on the left side of the motorcycle has a protrusion caused by the oil filter bay.  So, to make the angle iron fit correctly, you need to place a couple of spacers between the angle iron and oil pan holes.  On mine, I found some M10 nuts that were of the correct thickness to serve as a pacer.  I silver soldered the nuts to the back side of the angle iron so that they would be a permanent fixture on the jig.  I used a M8 clearance drill to make sure that the actual mounting bolts would be a slip-through fit.
Offline White Dog
« Reply #4 on: August 30, 2016, 09:39:40 PM »
Maybe I haven't looked low enough but all I saw on the left side of the engine are the factory crash bar and the 3 header pipes.  I tried to post a picture above but not sure it is visible.
  • Basement Garage
  • '95 K75 ABS.
'95 K75 ABS Red
2008 Goldwing Black
Reside in NC
« Reply #5 on: August 30, 2016, 09:44:03 PM »
The OEM crash bar bolts on using both of those holes.  You'll have to remove the left hand crash bar to access the holes for this purpose.
Offline White Dog
« Reply #6 on: August 30, 2016, 09:56:46 PM »
Ok, thanks for the info.
  • Basement Garage
  • '95 K75 ABS.
'95 K75 ABS Red
2008 Goldwing Black
Reside in NC
