Author Topic: Red triangle warning light  (Read 13221 times)
Offline cgdan
« on: August 28, 2016, 08:59:45 AM »
Hi Guys, just ticking off the jobs to get the brick going. The red triangle warning light is always on when I turn on. So I bypassed the BMU as per the guide on this forum, is there anything else that will trigger this light?
Cheers
Dan
  • United Kingdom
  • 1991 K100 LT
Re: Red triangle warning light
« Reply #1 on: August 28, 2016, 10:01:56 AM »
Anything else besides having a tail light or brake light not working, a brake light modulator installed that interferes the BMU function or a problem with ABS? You've eliminated those?
Offline cgdan
« Reply #2 on: August 28, 2016, 10:12:59 AM »
Nope, I haven't (doh!). So abs problems can set cause this light to illuminate?
  • United Kingdom
  • 1991 K100 LT
« Reply #3 on: August 28, 2016, 10:38:33 AM »
One purpose of the light is to warn of rear bulb malfunction; the other is to monitor the ABS. Read up!
Offline TrueAce
« Reply #4 on: August 28, 2016, 10:53:54 AM »
When you start the bike the ABS and BMU delta warnings will display. After the bike rolls about ten feet, the lights should cycle off, sometimes the front and rear brake may need a light tap. The usual suspect causing the delta warning to stay on is a bad brake light bulb, which you don't usually notice unless you ride the bike ten feet, leave it running, and activate the brakes to verify the brake light comes on. Go replace your rear brake light bulb and report back.
  • Florida
« Reply #5 on: August 28, 2016, 10:56:40 AM »
Could be the a faulty tail light triggering it but the police usually will spot that and pull you over in the US.
Offline cgdan
« Reply #6 on: August 28, 2016, 11:02:52 AM »
Apologies Laitch, should have read that first!  I guess as I haven't ridden it anywhere yet I may be looking for something that isn't there. I was reading wrong wiring diagram and couldn't see how that interacted, so that was't helping. Off to sit on the naughty step!
  • United Kingdom
  • 1991 K100 LT
Offline TrueAce
« Reply #7 on: August 28, 2016, 11:04:26 AM »
That's just one of many public services from the boys in blue, but you can waste a lot of time riding around looking for a police officer to ask to check it.
  • Florida
« Reply #8 on: August 28, 2016, 11:15:38 AM »
That's just one of many public services from the boys in blue, but you can waste a lot of time riding around looking for a police officer . . .
No problem, Ace. They'll find you, if they're in the mood.
Offline F14CRAZY
« Reply #9 on: August 28, 2016, 12:02:50 PM »
This is interesting. Drake seems to have wired mine up so it comes on when the sidestand is down
  • Grand Rapids, MI
  • '87 K75C
