Author Topic: Motor Swap  (Read 3420 times)
Offline Thom
Motor Swap
« on: August 23, 2016, 09:30:39 AM »
Found a crashed, low mileage 1986 K75C that I would like to buy for the motor. Is it a direct replacement for my (Non ABS) 1990 K75RT? I realize the rear wheel/brake is different but would separate the motor from transmission and install it with its original injection setup, ignition, etc. Also, if the trans is the same can I swap them as a unit and just replace the swing arm, drive shaft and wheel, or maybe just the wheel/brake assembly? All the bodywork is removed from my RT and it's been somewhat of a cafe bike, lately. Any advice is appreciated.
  • Southern NJ
  • 1990 K75(RT) Cafe Racer
Offline Brad-Man
Re: Motor Swap
« Reply #1 on: August 23, 2016, 01:23:46 PM »
Engine and trans can swap directly.
  • Marietta, GA
  • '85 K100
'74 RD350
Offline Thom
Re: Motor Swap
« Reply #2 on: August 23, 2016, 03:35:13 PM »
Thank you.
  • Southern NJ
