Author Topic: Help, great bike won't start  (Read 11408 times)
GreenvilleK100LT
« on: August 23, 2011, 07:32:53 PM »
First some background.  Not really new to BMW's, had an r1200c with many issues, but a great ride, also multiple japanese sport bikes and now I have a Duc 848.
My father picked up a 91 (I think) k100lt.  It's red, awesome bike.  I came to greenville to visit him, took it for a ride, it was unbelievable for being 20 years old.  You barely had to touch the starter to get it going.  I mean literally tap it, and boom, fired up.  A big difference from my 2 year old ducati with 3000 miles on it that takes 5 seconds of cranking to start....  oh well.  It's Italian.  Moving on.
Got back from the ride, he asked me about the his fuel gauge not working, I said I'd take a look.  Opened up the upper dash area below the windscreen and found a disconnected yellow wire.  Traced out some continuity with a multimeter from the 4 pin connection behind the side panel just to be sure.  Then tested the gauge by sticking a 9v across it and making sure it moved, reconnected the yellow wire to the proper terminal, put the bike back together and..... it doesn't start.  Starter motor turns, will check spark in the morning.  What I have found is that the fuel pump doesn't appear to have power.  Please bear with me here, I spent all day yanking the tank off and trying to troubleshoot this so I may wander a bit in my explanation.
Connector behind side panel has 4 wires and from what I can tell, they are as follows:
Brown - Earth
White - constant 12V after kill switch is put in run position, appears to supply voltage to slide pot that is the fuel gauge attached to the float
Green with a black stripe - 12V when i depress the starter switch (fuel pump?)
Yellow - appears to be the wire that supplies fuel sending unit's signal to the gauge.
Correct me if I'm wrong there, but that's what I came up with.
Next, when I metered the pump in the tank, I have no 12V to it both with the engine kill switch in the run position and with the starter button depressed.  My understanding from looking over your forum is that the pump doesn't run until after the starter button engages the FI relay.  That's different than I'm used to, but it's logical.
So now for where I'm stumped.  I have 12V across the green and brown wires coming from the bike.  I'm not even worried about yellow and white unless you guys tell me I should be.
I have continuity from the green pin of the male FSU connector all the way to the screw on jack that connects to the pump.
Likewise I have continuity from the brown pin on the male FSU connector that becomes a black wire going to a screw terminal on the fuel pump.
My thought is that if I plug the 4 pin back into the bike, I should see 12V across the 2 screw terminals, but I don't.  I don't get any voltage there....  It's very frustrating.
FYI I touched a 9v battery to the pump to be sure it spun and it did.
Any info would be greatly appreciated.  I'm contemplating running down to the dealer and picking up an FSU and plugging it in to see what would happen, but would really like to figure this out so I don't blow $100 on something that could be fixed easier.   Thanks again, pardon the long post.
Re: Help, great bike won't start
« Reply #1 on: August 23, 2011, 07:50:20 PM »
Not real familiar with the K100's as I have a 1100 but a faulty side stand switch will cut the fuel pump off and usually is the culprit on the 11's.
Rick G
« Reply #2 on: August 23, 2011, 08:17:38 PM »
Make sure that 4 pin connector is connecting they are very problematic. I have had personal experience with 2 and know of many others that have caused much grief.
« Reply #3 on: August 23, 2011, 08:30:49 PM »
+1
Try shaking that connector to see if it's the problem.
GreenvilleK100LT
« Reply #4 on: August 23, 2011, 08:47:43 PM »
Copy that, thanks guys, I was starting to suspect it was the something intermittent like that.  will attack it again in the morning, hopefully I can get her back up and running tomorrow.  I'm simply stunned by how great a bike it is and can't wait to ride it again.
Great forum y'all got here.  If I can convince my wife that I need to have a k-bike in Hawaii in addition to the Duc, you'll see me here a lot more. :D
GreenvilleK100LT
« Reply #5 on: August 24, 2011, 09:49:43 AM »
Geniuses, the lot of ya!   ;)
Sure enough it is the connector.  I hook up my voltmeter to the pump electrical and I can get 12V to it when I wiggle it.  Is there a quick fix? or a way to just replace these two connectors?  have guys just been buying a generic 4 pin and redoing it that way?  I'm open to ideas.  Would prefer to keep the factory connector, but I've got lots of bikes with non-oem connectors so it doesn't bother me THAT bad.
Thanks again.  I had become completely stumped and despite my background with electronics, I was just missing that the connector was causing the issues.
GreenvilleK100LT
« Reply #6 on: August 24, 2011, 10:21:24 AM »
Running to the store now.  Thanks.  great forum you guys have here!
GreenvilleK100LT
« Reply #7 on: August 24, 2011, 08:10:28 PM »
Ok all done, well, all done hours ago then I went for a nice long ride :D.  Looks great.  Sadly, I didn't have a big piece of heatshrink, but I had enough for the individual wires.  I'll send my dad a hunk of 4:1 from work when I get back there and he can slide it over the connector to finish it off.
Excellent suggestion.  Thanks again.  Amazing that it was just the little connector and that it was working fine until I unplugged it and plugged it back in.
On a side note, the guage is working again too, not 100%, but I think the float may have just got caught on something in the tank.  When it's close to empty again I'll stick my hands down in there and see if I can free it up.
Again, thanks so much for your help.  Really appreciate it!
« Reply #8 on: August 24, 2011, 08:19:55 PM »
Sometimes the "ping pong ball" float fills up with gas which can cause it to read low or not float.
