Author Topic: K100 Speedo ribbon to three pin fixture delaminating...  (Read 6857 times)
Offline Brahma
« on: July 23, 2016, 08:35:45 PM »
Over the years, my speedometer pins have had to be messed with enough that it appears now the ribbon is delaminating.  Again, I had to look at the pins today after intermittent speedo readings started occurring again for the first time in a couple years. This time, I noticed that the ribbon is delaminating, which over time, could spell curtains for the odometer.  I cleaned and tweaked the pins- something I haven't done before, and put a light carbon conducting lube on them and reseated. I also put foam over the pins,but stuck them to the outter case, that when put back on, applies force to the pins.  Maybe this will help the intermittent problem.
As a question- has anyone done a complete ribbon bypass with direct-soldered wires to the speedo as a permanent fix?  It appears that the engineering of the bike will outlast the cluster- my intermittent speedo is looking terminal...  Pun intended...
1985 K100RT (First bike, still own)
2006 R1200GS (Recorded Iron Butt Ride- Sold)
2006 K1200GT  (Sold)
2011 R1200GS Triple Black (Sold)
Re: K100 Speedo ribbon to three pin fixture delaminating...
« Reply #1 on: July 23, 2016, 09:10:00 PM »
  It appears to hat the same big erring of the cluster will not out last the bike . . .
I swear that my cluster erring is differently small.
Offline Brahma
« Reply #2 on: July 23, 2016, 10:17:33 PM »
Stupid iPhone auto-correct.  I cleaned it up.  :)
And they want to make driverless cars.....
2006 K1200GT  (Sold)
Offline Brahma
« Reply #3 on: July 24, 2016, 10:34:11 AM »
Just got back from a steaming hot, 100 mile ride north of Tampa, at 80+, and the speedo didn't miss a tic from the beginning. I do think my idea of constant pressure against the pins and for about a 1" square area will do wonders....
2006 K1200GT  (Sold)
« Reply #4 on: July 24, 2016, 12:35:24 PM »
BMW did have the same idea in -86.......this connection have been modified by BMW several times,
the final mod was a two 4 mm screws.
Offline Brahma
« Reply #5 on: July 24, 2016, 04:06:02 PM »
Very interesting- have pics?
2006 K1200GT  (Sold)
« Reply #6 on: July 24, 2016, 07:54:56 PM »
Final mod............
Offline Brahma
« Reply #7 on: July 24, 2016, 08:35:21 PM »
Interesting!  Thanks!
2006 K1200GT  (Sold)
Offline thecableguy
« Reply #8 on: September 06, 2016, 10:48:12 AM »
Is the ribbon cable pictured above with the plastic bracket with provision for two screws available from BMW? I've looked thru the fiche at Max and I'm not sure I see it...
Jim
  • Madison, WI USA
  • 86 K100RT - Brünhild
Offline thecableguy
« Reply #9 on: September 06, 2016, 12:22:04 PM »
Nevermind, I see it now. It's part of that whole central assembly. 62 11 1 459 902 NLA
Arrrg.
  • Madison, WI USA
