Hey Guys,
So I dumped my bike on a slick dirt road. Very minor. Did some fairing damage and now my ABS has quit. When I turn on the key I get the alternate flashing. I have fallen over with my bike before, but never on the run, and the ABS worked fine afterward. Now after "the fall" it is out of commission!!! Any guessees
Bizz
So resetting the ABS is different for ABS II. It is in the links posted here, but not so easy to find. One site link, it is triple linked, and hard to follow. And another link, it is posted, but not labeled as to which is which. I missed it on both counts. Frankenducks primer in the Tech library doesnt cover ABS II so here ya go.
ABS II Reset:
1 ignition off
2 ground center terminal of diagnostic plug
3 ignition on but no engine start
4 if you see two warning lamps illuminate alternately step 2 above is effective, if not you need to polish center terminal hole and try from step 1 ( possibly corroded center terminal)
5 push abs cancel switch on console for more than 10 sec.
6 step 5 will turn on abs lamp and turn off other warn lamp.
7 release abs cancel switch. two lamps go on if your reset is successful.
8 turn off ignition. remove ground wire if you succeeded.
how is the result.
