HF has a plastic welder pretty cheap. Anybody had any success with it? I have two complete sets of cases to sell -- 1 system and 1 city -- but they have cracks. I used 2 part epoxy and fiberglass a couple years ago but although it appears to adhere well at first, it begins to separate after a time and a couple years later you can just peel it off. I thought I'd prepped the surface but either I didn't or West Systems epoxy doesn't or I didn't do it right.
What I did was cut the cloth, lay it out with epoxy on a separate surface, brush out a layer of epoxy on the surface, wait till tacky, the press the cloth onto the surface. Like I said...good for maybe a couple years, then fail. Plastic welding would be much better if someone could demonstrate that it works.
I got a small sheet of similar ABS at a boat maker in Annapolis....for welding you'd probably need to source it for someplace like that.
Laitch, how long has your epoxy patch job been good for?
