Author Topic: Red Brake Test Light Stays On  (Read 9386 times)
Offline tweather
« on: July 12, 2016, 12:33:58 PM »
About a week ago it happened for the first time, but only stayed lit for a few minutes before turning off during my drive. I, foolishly, hoped that it had "solved itself."
From what I can tell, all of lights are operating properly. How concerned should I be? Any ideas what might be causing this? I need the red light of shame to go away so I can ride with full attention on my surroundings, instead of wondering what is causing the bright red light in my peripheral vision.
  • Denver, CO
  • 1994 BMW K75RT; 1995 K1100LT
Online Laitch
Re: Red Brake Test Light Stays On
« Reply #1 on: July 12, 2016, 04:17:16 PM »
Carry spare brake light and tai light bulbs, learn how to install them then keep riding.
Offline tweather
« Reply #2 on: July 12, 2016, 05:00:07 PM »
Maybe I'm missing something, but that doesn't seem particularly helpful. :dunno2: I do carry extra bulbs, but they are all working properly and don't need replacing.
I was hoping to find out why the light has begun to remain on after depressing both brake levers.
  • Denver, CO
« Reply #3 on: July 12, 2016, 06:30:27 PM »
The BMU light is saying that a bulb is burnt out.  This could be a broken filament but it could also be a poor socket connection; both produce the same results.  However only one fixes itself - guess which.  You should be investigating why the bulb does not make good contact with the socket.  I have read forum posts that talk about modern 1157 bulbs not mating well with the European sockets on the K-bike but I can't find a reference for you right now.
Online Laitch
« Reply #4 on: July 12, 2016, 06:33:41 PM »
  :musicboohoo: It's hard to find good help sometimes at these rates, tweather.
You can always put tape or one of those cheerful children's band aids over the light; otherwise—following on from RBM's helpful post—you might try cleaning the unit's contacts. You can read a description of it starting at item 2. there and more about it here.
Offline tweather
« Reply #5 on: July 12, 2016, 06:54:27 PM »
Laitch, you're totally right. Thank goodness for those nice guys up north, eh?
Thank you (both of you) for your help. I'm not well versed at diagnosis, but I do like working on my vehicles myself. This was exactly the information I needed.
  • Denver, CO
Online Laitch
« Reply #6 on: July 12, 2016, 06:56:05 PM »
Most everything's north of you, tweather. Good luck.
Offline Brad-Man
« Reply #7 on: July 13, 2016, 10:29:31 AM »
I think you both need to be reminded that there has been good help from people WAY South of NA...
  • Marietta, GA
  • '85 K100
'74 RD350
Online Laitch
« Reply #8 on: July 13, 2016, 11:00:55 AM »
Good point, Brad-Man. I nominate you for the MOTOBRICK.COM Chair of Inclusivity.
Offline Brahma
« Reply #9 on: July 24, 2016, 09:04:28 PM »
Check your rear brake light switch- they have to take a lot of abuse in that location.  Flush it with a few spurts of wd-40, but it might be toast.  I've replaced several over the decades.
1985 K100RT (First bike, still own)
2006 R1200GS (Recorded Iron Butt Ride- Sold)
2006 K1200GT  (Sold)
2011 R1200GS Triple Black (Sold)
Offline tweather
« Reply #10 on: October 18, 2016, 12:25:58 AM »
So, it was brought up that I didn't clearly resolve this thread.
It was a poor socket connection. The socket had been deformed by a higher wattage bulb overheating the socket and causing poor contact. I replaced the bulb and socket.
No more red light.
  • Denver, CO
« Reply #11 on: October 18, 2016, 01:01:16 AM »
Mine hasn't worked for so long it took a minute for me to figure out what you were talking about.  Fortunately, my warning light stays off.  Could be the first stage of the ultimate demise of the machine, at this rate it will still outlast me.
Online Laitch
« Reply #12 on: October 18, 2016, 09:08:30 AM »
Thanks for the update, Tweather. It's likely more than a few wiring problems have been cause by out-of-spec bulbs.
The bulb monitor feature has been helpful for me a couple of times while riding and I'm glad I have it. If it ever fails and can't be resuscitated, I'l buy a Motogadget and start a long chain of queries to rbm. :giggles.
Offline 84K100RT
« Reply #13 on: November 03, 2016, 12:52:09 PM »
It comes on solid if
A failed bulb. replace it.....
A poor connection at the rear light or brake light bulb. Clean it up.
A failed/faulty front or rear brake switch. Replace it.
On the K100 4 valve the brake switches and clutch switch are interchangeable.
It flashes if its an ABS fault.
  • Ireland
  • 92K100LT 84K100RT
Offline jay1622
« Reply #14 on: November 05, 2016, 10:28:07 AM »
Figured I'd add to the thread with the following for those who stumble upon it in the future...
To test the brake light switch/circuits...
Test the brake switch(es) by disconnecting them at the connector and use a multimeter to confirm the presence/loss of continuity as the switch is engaged/disengaged. Obviously, you're testing the connector on the wire attached to the switch, and not the connector on the wire that leads to the wiring harness. Remember, the switch may behave differently if it is installed in their respective locations, as opposed to being removed and manipulated by hand. DAMHIK.
Test the particular circuit controlled the respective switch by creating a jumper and closing the circuit at the wiring harness end of the connector.
  • Charlotte
  • Previous: 1986 K75S, 1977 R75/7, 1999 R1200C, 2003 R1150GS, 2001 F650GS, 2005 R1200RT... Current: 2005 R1200RT and my Brick, a 1988 K75S
