Author Topic: Removal of K100 front fender mount  (Read 3939 times)
Offline thor0864
« on: July 09, 2016, 03:56:59 PM »
Doing a cafe racer out of my straight K100, and it seems a lot of guys are removing the bracket that holds the front fender, then fitting an aftermarket fender in the more standard way using the 2 Bolt holes on either side. Until I saw others doing this, I had assumed that that bracket had a structural purpose as well, strengthening fork rigidity. Now I'm pretty sure that it's nonessential. Can somebody confirm this?  Thanks, Stein
  • Ottawa, Canada
  • 1986 K100
Re: Removal of K100 front fender mount
« Reply #1 on: July 09, 2016, 04:20:41 PM »
if you have the one piece finder you're fine.  The later 2 piece fender has an aluminum fork brace between the front and back fender halves and is pretty essential.
Offline thor0864
« Reply #2 on: July 11, 2016, 10:54:47 AM »
Thanks for the quick reply! Yes I should have clarified that I do have the two piece fender unfortunately.  Sorry to hear you think it's structural, since it's so damn ugly when the stock fender is removed.  May opt to replace with a custom piece that's less unsightly.  No idea why other bikes are fine with the fork braced at two fixed points (axle and top), whereas you're saying I need a third brace point, seems excessive.  Anyway I'll likely follow your advice, thanks again, S.
  • Ottawa, Canada
  • 1986 K100
