Author Topic: K100LT Running rich  (Read 4372 times)
Offline alex-wilson
K100LT Running rich
« on: June 29, 2016, 01:41:55 PM »
Hi brickers :-)
I apologize in advance for this long post :-)
I have having quite a problem with my K100LT 1989 56.000KM.
I bought it a few weeks ago. The former owner has chopped the backend for café racer look. He has also put on a K1100RS exhaust with catalytic converter (Don’t ask me why).
It is running so rich that it won’t run when hot more than 50*C (measured at the water temp sensor). The sparkplugs are completely black. It chops and shoots out smoke.
When I try starting it when it’s cold, it won’t start at first starterbutton press, but it starts at second attempt.
If I unplug the 3 vacuum nipples & the vacuum hose to the FPR, it raises in rpm and it runs smoothly.
I have been through most of “bike won’t start” pdf, and here is things I have tried:
Ground:
Unscrewed the ground connectors under the tank, sanding them with a light sandpaper and put them back on. Unscrewed the ground connection on the gearbox and done the same.
Result = No change.
Clean Jetronic connector:
Result = No change.
Idle switch:
Tried starting the bike without the idle switch connected.
Result = It starts at first starterbutton press.
Fuel filter:
Changed the fuel filter.
Fuel pressure:
Measured the pressure from the gastank to the injector rail.
Result = I think its fine. (I only have a gauge from 0-10psi and one from 50-300psi. But it looks like it’s at about 36psi.
Airflow meter:
Measured at the LE-Jetronic female connector.
Result = Very close or the same at the values in the pdf.
Water temp sensor:
Result = Seems to be the same as the pdf.
Hall sensors:
On a cold engine (not run for 12h) heat up with a hair dryer and start the bike.
Result = No change.
FPR:
While all the vacuum nipples where unplugged I have tried sucking on the vacuum hose to the FPR
Result = Raise in RPM.
I then tried with a big syringe so it was easier to control – I pressed the syringe (Like blowing air into the FPR) = Lower RPM and a lot of smoke.
After this I have not been able to get it to run smoothly again.
-   I am thinking a defective FPR? As it might be stuck or running very badly up and down.
Hope you have some ideas  :clap:
  • Denmark
  • K100 LT
Re: K100LT Running rich
« Reply #1 on: June 29, 2016, 02:17:30 PM »
Fuel pressure:
You think it's fine because you don't have a gauge accurate enough to tell you it's "fine"?  It could be off by 25 psi in one direction and 15 psi in the other. It may well be "fine" but perhaps you should consider take a more accurate measurement than by sight.
  • 1995 K75 89,000 miles
Offline alex-wilson
« Reply #2 on: June 29, 2016, 02:48:26 PM »
That's correct, I am trying to locate a proper gauge. The one that goes from 0-10 is half vacuum and half pressure, so it goes past the number 10, but goes over in the pressure part of the meter. That why I'm guessing it fine :-)
  • Denmark
  • K100 LT
