Author Topic: Protective bushings between tank wall & the pump housing?  (Read 2708 times)
Offline jay1622
« on: June 28, 2016, 09:07:40 AM »
Searching for what these are using my bikes VIN and also the engine codes of a few later models. I tried searching terms like... cut hose, damper, buffer block, rubber bushing and all sorts of other stuff and have yet to find anything. Mine were so rotted, I'm guessing I mistook them for partially disintegrated fuel hoses. No bulletins either. Protective purposes I'm sure, but no mention or part numbers. Is this just an add-on? I've seen them quite a few times while searching other pump related stuff.
  • Charlotte
Re: Protective bushings between tank wall & the pump housing?
« Reply #1 on: June 28, 2016, 12:21:50 PM »
Undoubtedly, reading along in this K100 forum thread will help make everything clear, jay. :giggles
  • 1995 K75 89,000 miles
Offline Elipten
« Reply #2 on: June 28, 2016, 06:53:49 PM »
Mine were shot so I used some fuel line designed to be submerged in gasoline
  • San Antonio, TX
  • 1990 K75RT
