Author Topic: forks  (Read 4536 times)
Offline franck
forks
« on: June 27, 2016, 12:22:19 PM »
I have recently renovated my K75C (1985) and been riding it for a few months. The K75C has a some time been fitted with a full fairing possible of a K75RS.  The bike runs well, and no problem in cornering - however on rough road surfaces I get quite a bit of front end vibration - most of the roads in my area a surfaced country roads and in places heavily patched.  Should I use a more viscous fork oil (at the moment 10w)  or could this be the start of a fork rebuild?
  • France
  • K75C
Re: forks
« Reply #1 on: June 27, 2016, 07:28:48 PM »
If by "shake" you mean the forks don't follow sharp bumps in the road very well, then the high speed compression damping is too high.  Use a less viscous fork oil.  Something like 20 Cst (usually a 5W oil).  There is very little you can do with K75 forks - just set preload and play with oil viscosity.  There are no rebound damping control or high speed valving like modern sports bikes.
Re: forks
« Reply #2 on: June 27, 2016, 08:52:20 PM »
What do you have mounted for a tire(type/brand) and at what pressure.......
Offline franck
Re: forks
« Reply #3 on: June 28, 2016, 02:36:42 PM »
Tyres mounted on the bike
Make Bridgestone     front 100 90 18   Rear 120 90 17    (drum brakes)
I keep the tyre pressures a bit above recommended as I have had some pressure loss due to leakage at the level of the rims (the bike was left standing for some years)   Pressures    front 32 psi rear  36 psi
  • France
  • K75C
Re: forks
« Reply #4 on: June 28, 2016, 04:04:14 PM »
Did you put new tyres on the bike when you put it back on the road.
C.heers Martin.
Re: forks
« Reply #5 on: June 28, 2016, 05:07:13 PM »
If those were the tires on the bike when it was standing for years, they may have deformed. Replace them before you do anything else.
Offline franck
Re: forks
« Reply #6 on: June 29, 2016, 04:43:58 AM »
They are new tyres - it was the first thing I did after clearing out a nest of mice from the air filter chamber and general heavy maintenance.   I think the problem with the tyres losing pressure was corrosion on the rim.  I had the tyres remounted and this time I took some pains to make sure the contact surface was cleaned up.
  • France
  • K75C
Re: forks
« Reply #7 on: June 29, 2016, 03:39:13 PM »
Try  raising 2 PSI front and rear.
C.heers Martin.
