Author Topic: 96 K1100RS Stuck At 6000 RPM Idle  (Read 2954 times)
« on: June 22, 2016, 07:40:06 AM »
im out here in logan utall on the motomadness ride...
on the way to logan i down shifted to make a hard left... no slow down... no no no... revs would not go below 6k...
got off... reset motronic connector... same thing... instant 0 to 6k when it started...
disconnected the tps plug... instant 2000 rpm then slow build up to 4500 rpm...
so... im stuck... looking for advice as how to proceed... is it a vacuum leak... is it the motronic...
i searched and found no reference to this kinda whack...
what say you...
Re: 96 K1100RS Stuck At 6000 RPM Idle
« Reply #1 on: June 22, 2016, 07:50:49 AM »
If your cruise control is electronic, disconnect it, jo.
  • 1995 K75 89,000 miles
« Reply #2 on: June 22, 2016, 10:27:27 AM »
got it... cooler heads prevailed after 14 beers and 3 hours sleep...
my electrinic supercharger was feeding negative vacuum into my positive pressure fueli squirter...
rolling with the pack...
yeeeeeeehaaaaaaa...
« Reply #3 on: June 22, 2016, 10:41:41 AM »
This just demonstrates how sufficient sleep and hydration restores reasoning.
