Author Topic: K75 fichtel sachs vork with brace in k100 2v  (Read 4615 times)
Offline Barney Hooglax
« on: June 19, 2016, 11:47:33 AM »
Hallo, i want to use a bmw k75 fork in my BMW k100 because of the fork brace.
I want to put my almost new k100 progressive springs in the k75 fork with brace.
Is that possible?
Ive bought a 41.3mm sachs fork (or brembo in schedele)
The dimensions look the same.
http://www.k100-forum.com/viewimage.forum?u=http%3A%2F%2Fi56.servimg.com%2Fu%2Ff56%2F17%2F70%2F28%2F81%2Fk__r_f10.png
  • The Netherlands
  • Bmw k100 2v
Re: K75 fichtel sachs vork with brace in k100 2v
« Reply #1 on: June 22, 2016, 12:23:24 AM »
Is that possible?
Go here. Click on the box Start Here—Your Ride. Indicate the year and model of your K75 then click on the box Fork Spring Kit. Write down the kit part number. Do the same with the model and year of your K100. If the kit part numbers are the same, it will work. You may need to adjust the length of your spacer tubes.
