Author Topic: Project DevilK75S  (Read 21749 times)
Offline Devil K
Project DevilK75S
« on: June 16, 2016, 01:46:10 AM »
This thread will be dedicated to turning my 1994 BMW K75S into a cafe bike... more or less at least.
  • Kernville
  • 1994 BMW K75S
Offline Devil K
Re: Project DevilK75S
« Reply #1 on: June 16, 2016, 01:53:45 AM »
When I first got this bike I knew that the transmission was bad. During repairs i soon found out that the drivshaft was bad as well. Since then i have given the whole rear end of the bike a complete overhaul. New used 5 speed transmission, custom driveshaft, the previous owner installed a new used final drive (I wonder if I can find another final drive with taller gears?). Shortly afterwards though I snapped my clutch cable. I have found another one on ebay, just waiting for funds to order it.
  • Kernville
  • 1994 BMW K75S
Offline Devil K
« Reply #2 on: June 16, 2016, 01:57:35 AM »
Here are some photos from the overhaul
  • Kernville
  • 1994 BMW K75S
Offline Devil K
« Reply #3 on: June 16, 2016, 01:59:23 AM »
More photos of the tranny and shaft replacement.
  • Kernville
  • 1994 BMW K75S
Offline Devil K
« Reply #4 on: June 16, 2016, 02:01:22 AM »
So on my quest to build my dream bike This little bastard decided to snap on me
  • Kernville
  • 1994 BMW K75S
Offline Devil K
« Reply #5 on: June 16, 2016, 02:03:31 AM »
Aha!!! I got so excited it fired up on the first try. All of that hard work finally paid off.
[attachment[/attachment]
  • Kernville
  • 1994 BMW K75S
« Reply #6 on: June 21, 2016, 02:22:11 PM »
That does not look like a K75S.  Looks like a base model/75C.
What is the VIN?
Offline Devil K
« Reply #7 on: June 21, 2016, 02:29:31 PM »
I don't have it on me, I'll check when I get home.
  • Kernville
  • 1994 BMW K75S
Offline The Dude
« Reply #8 on: June 21, 2016, 02:57:44 PM »
What is the VIN?
It's a hybrid.
Rear brake would be a drum,the final drive ratio will by lower ratio too.Forks are the next distinction.
Dressed as a C.
  • Auckland, New Zealand
  • K75s
Current.
TR6R 1973 from new.
All the best!
« Reply #9 on: June 21, 2016, 03:47:01 PM »
94 S model vin's start with 0154xxx
i don't see any S bike parts on yours.
« Reply #10 on: June 21, 2016, 05:51:01 PM »
A stock K75 wouldn't have bar weights either. It's hybridized, like Dude said. A C would have a slightly differing headlight assembly, too. It looks to me like a Standard that got a C-bar. It's the perfect candidate for cosmetic surgery. Pretty good pics, Devil.
Offline Devil K
« Reply #11 on: June 21, 2016, 07:34:34 PM »
What's body type model:rs
  • Kernville
  • 1994 BMW K75S
« Reply #12 on: June 21, 2016, 08:36:19 PM »
Reisesport
Where'd you get that abbreviation?
Offline Devil K
« Reply #13 on: June 21, 2016, 08:39:25 PM »
So it has a c bar, does that mean that it's a mid/high rise handlebars? The first digits of the vin are 1057
  • Kernville
  • 1994 BMW K75S
« Reply #14 on: June 21, 2016, 08:40:27 PM »
Don't be coy. Answer my question, Devil.
Offline Devil K
« Reply #15 on: June 21, 2016, 08:41:48 PM »
I'm the non-op
  • Kernville
  • 1994 BMW K75S
« Reply #16 on: June 21, 2016, 08:43:28 PM »
Offline Devil K
« Reply #17 on: June 21, 2016, 08:43:58 PM »
On the nonop. But if this is a hybrid then the fucker I bought it from lied to me...I just bought a clutch cable for low rise handle bars too.
  • Kernville
  • 1994 BMW K75S
Offline Devil K
« Reply #18 on: June 21, 2016, 08:50:20 PM »
I thought for sure the rear disc brake was a give away
  • Kernville
  • 1994 BMW K75S
Offline Devil K
« Reply #19 on: June 21, 2016, 09:04:20 PM »
Not to mention it has a 17 in the rear. It's deffinetly not stock but I'm 99 percent sure that it's an S.
  • Kernville
  • 1994 BMW K75S
« Reply #20 on: June 21, 2016, 09:54:05 PM »
It's a beautiful evening. I think I hear barred owls hooting in the distance.
« Reply #21 on: June 21, 2016, 10:55:09 PM »
Wrong first digits.  The VIN usually refers to the last 7 digits in that long series.   The first part is other codes saying where it was made and other info. When I said first four it was the first four of that 7.  What are the last 7 digits of your vin?
  VIN Last 7 digits should be 0154xxx.  Mine was the first 94 S made.  Vin 0154291.  Yours would be higher than 291.
You can also put your last 7 into realoem.com and it will tell you what it is.
« Reply #22 on: June 21, 2016, 11:03:53 PM »
Yep, those are barred owls all right.
Offline Devil K
« Reply #23 on: June 22, 2016, 12:56:03 AM »
I think that you guys are right. It's a standard
  • Kernville
  • 1994 BMW K75S
Offline Devil K
« Reply #24 on: June 22, 2016, 01:06:17 AM »
0134935 are the last seven digits.
  • Kernville
  • 1994 BMW K75S
