Author Topic: Throttle cable change out  (Read 6678 times)
Offline Donmystic1
« on: June 12, 2016, 08:49:54 AM »
I have to change the throttle cable on my 1985 Naked K100. which I have converted to a RT.
I have to change one hose and one cable for the higher handle bars. (The hydraulic brake line and the throttle cable.)
I need the upgrade kit that fits down near the throttle rack on the left side of the engine .
Does anyone have any photos or videos of the procedure to change the cable going into the throttle on the handlebars.
Thanks
Don
  • Mystic, CT
  • 1985 K100, 1985 K100RS, 1986 K100RS Turbo,1985 K100RT
Offline jay1622
Re: Throttle cable change out
« Reply #1 on: June 13, 2016, 10:35:13 AM »
Thanks
Don
Remove the screw that retains the electrical switches and push it straight down which will release it. Open your throttle from the handgrip and put something somewhere that will hold the  throttle in the open position. Unscrew the throttle grip cap and wiggle it upward. This will expose the cable allowing you to release it. Make sure your throttle grip and the gear marks are in line with each other upon installation.
You can release it two little hex bolts securing the brake master cylinder also, but that wasn't necessary when I did mine.
  • Charlotte
Offline Donmystic1
« Reply #2 on: June 13, 2016, 11:56:29 AM »
Just what I needed. Thank you
Don
  • Mystic, CT
Offline Donmystic1
« Reply #3 on: June 13, 2016, 12:03:32 PM »
Jay, if you changed out your cable did you use the new improved version.
If so, do you have any pictures of the bracket that mounts near the throttle rack on the left side. This allows the cable to be adjusted.
items number 3, 4 5, & 6
  • Mystic, CT
Offline jay1622
« Reply #4 on: June 13, 2016, 01:26:11 PM »
I had just lubed the old one and reinstalled it. It was in fairly decent working order.
  • Charlotte
