Author Topic: '85 K100RT Build - "TT" Endurance Racer  (Read 14025 times)
Offline zroadhouse
« on: June 04, 2016, 12:25:05 PM »
Hello all!
This is the start of my K100 "TT" build thread on the Motobrick forum. :)
Austin has been the host to two great events for the past several years: MotoGP at Circuit of the Americas and the Handbuilt show. After going to this year's show, I felt inspired to build a bike. In the past I've dabbled with cafe-racering my old Street Triple and built a race bike out of my Daytona 675R. For this project I wanted to start with something older, simpler, and less expensive. A bike that I could tear down, put back together, and modify to my hearts content. I thought about R-bikes and old Hondas, but they are getting harder to come by unmodified and/or for a reasonable price.
A little over a month ago, I found a 1985 K100RT with 77k miles for a very reasonable price to use a the basis of my build. This bike had obviously been dropped on the right side, was missing some fairing pieces, no radio, etc. -- perfect for my purposes. I handed over the cash, and rode it home in a light rain, fairings shaking all the way home. I believe I'm the 5th owner (the 4th bought it to fix and flip it).
  • Austin, TX
  • 1985 K100RT
1985 K100RT
Offline zroadhouse
Re: '85 K100RT Build - "TT" Endurance Racer
« Reply #1 on: June 04, 2016, 12:44:00 PM »
Here's the progress on the tear down so far. At this point, everything is disconnected and ready for me to remove the frame. Before I do that, I'm going to test fit the fairings that are arriving today. :clap:
  • Austin, TX
  • 1985 K100RT
1985 K100RT
Offline zroadhouse
« Reply #2 on: June 04, 2016, 01:22:28 PM »
There have been a few small issues along the way.
  • The tank was missing its bracket - ordered a replacement from eBay
  • The oil pan looks like someone tried to pry out the filter with a screwdriver - ground the spots flat to 600 grit
  • Rear disc was thinner than .14" and was cracked. Rear pads completely worn down. - ordered a replacement rotor and pads from EBC
  • The drive splines were completely dry when checked. The female side looks completely ok, and the male side has a slight hook to it - moly'd both sides back up and reinstalled. Though I can't figure out how to torque those :nono bolts since the head of my wrench is too big. Likely I need hinged driver.
  • Austin, TX
  • 1985 K100RT
1985 K100RT
Offline The Dude
« Reply #3 on: June 04, 2016, 04:26:53 PM »
"Rear disc was thinner than .14" and was cracked. Rear pads completely worn down."
Thanks for reminding me to have a good look at mine....
  • Auckland, New Zealand
  • K75s
Current.
TR6R 1973 from new.
All the best!
« Reply #4 on: June 04, 2016, 06:32:15 PM »
Might as well take off the front master cylinder and brake lines, and reinstall with new lines when you put everything back together.
Offline zroadhouse
« Reply #5 on: June 04, 2016, 06:49:38 PM »
I'm planning on it. Hadn't gotten around to it quite yet. I'll definitely need new lines as I'm planning to have a fairing stay come up and out of the triple tree nut where the current brake line is. Weird that they routed it that way. Is that common on BMWs?
  • Austin, TX
  • 1985 K100RT
1985 K100RT
Offline zroadhouse
« Reply #6 on: June 07, 2016, 07:27:24 PM »
The frame is off. :)
  • Austin, TX
  • 1985 K100RT
1985 K100RT
Offline zroadhouse
« Reply #7 on: June 07, 2016, 07:29:22 PM »
And the fairings are in... :)
  • Austin, TX
  • 1985 K100RT
1985 K100RT
Offline jjs1234
« Reply #8 on: June 07, 2016, 07:41:05 PM »
ooh! Mind if I ask where the front came from?
  • Northern California
  • 1984 K100
Mr. Creative
Offline zroadhouse
« Reply #9 on: June 07, 2016, 07:48:33 PM »
Fairings and headlight are from Airtech Streamlining - F1F (XR69) + MORI2 tail + some handcuffs.
  • Austin, TX
  • 1985 K100RT
1985 K100RT
Offline jjs1234
« Reply #10 on: June 07, 2016, 07:59:22 PM »
So your planning to mod it? I didnt see a k100/1100 fairing on there. But it looks fierce!!
  • 1984 K100
Mr. Creative
Offline zroadhouse
« Reply #11 on: June 07, 2016, 09:15:49 PM »
Yes. This is a mod build. I'll be making fairing brackets, stay, etc. I picked this fairing based on style and size.
  • Austin, TX
  • 1985 K100RT
1985 K100RT
Offline Elipten
« Reply #12 on: June 07, 2016, 10:55:05 PM »
Now this is looking interesting and has my attention.
  • San Antonio, TX
  • 1990 K75RT
