I just bought a '92 K75 RT today and was so excited to take her out on her first little ride. I pulled out of my place, gaining speed with a smile on my face, when suddenly my elation was halted after I shifted into second gear. An alarming CLUNK sound, followed by the rear wheel locking up, sent me in a panic. I squeezed the clutch in to stop the skidding and to try preventing from highsiding. Luckily I wasn't going very fast. I coasted into a nearby parking lot confused and frustrated. I test rode the bike earlier that day and it shifted smooth 1-5, no problems at all. The guy I bought the bike from was a mechanic and apparently he maintained it regularly (I'm not putting it past me that he could be lying). Anyway, only getting 500ft from my house wasn't a good way to start the relationship with my bike. Although I'm thankful I wasn't on the freeway when it happened. I will be taking her apart soon and let you know what I find. But in the meantime, anyone have ideas on what could have caused the transmission to fail like that? -Danner
Not that it will come to it, but in-case you have to take the trans apart- no fear! its quite easy to do.
Looks like I may have been right about the thrown rod. Did you look to see if the oil pressure sender was didsconnected? Have you contacted the seller yet to see if he will give some compensation?With the price of used engines what they are,the good news is that you should be able to part out your old one for a good chunk of what the replacement will cost. Or have a nice supply of spares for cheap. Too bad this had to happen at the start of the riding season.
I forget but somebody on here had me check my rods if they were bent. Hydrolock?Wiki:Hydrolock (a shorthand notation for hydrostatic lock) is an abnormal condition of any device which is designed to compress a gas by mechanically restraining it; most commonly the reciprocating internal combustion engine, the case this article refers to unless otherwise noted. Hydrolock occurs when a volume of liquid greater than the volume of the cylinder at its minimum (end of the piston's stroke) enters the cylinder. Since liquids are nearly in-compressible the piston cannot complete its travel; either the engine must stop rotating or a mechanical failure must occur.
Dude, I'll take a look when I get the engine completely torn apartAce, no way I'm giving up yet!This where I got this weekend. Hopefully next weekend I'll get the engine more torn down.
Oh, Man, I think I just figured out what caused your problem...................sibling rivalry with a certain shiny silver Honda.
