Author Topic: First ride and only got 500ft  (Read 36702 times)
Offline danpalooza
Re: First ride and only got 500ft
« Reply #25 on: May 24, 2016, 02:45:23 AM »
I'm going to tear it apart when I get some free time, I'll post what I find. And seeing how available and inexpensive the engines are made me not freak out as much as I was.  :yow
  • Phoenix, AZ
  • 1992 K75 RT
Offline jjs1234
« Reply #26 on: May 24, 2016, 03:34:04 AM »
I just bought a '92 K75 RT today and was so excited to take her out on her first little ride. I pulled out of my place, gaining speed with a smile on my face, when suddenly my elation was halted after I shifted into second gear. An alarming CLUNK sound, followed by the rear wheel locking up, sent me in a panic. I squeezed the clutch in to stop the skidding and to try preventing from highsiding. Luckily I wasn't going very fast. I coasted into a nearby parking lot confused and frustrated. I test rode the bike earlier that day and it shifted smooth 1-5, no problems at all. The guy I bought the bike from was a mechanic and apparently he maintained it regularly (I'm not putting it past me that he could be lying). Anyway, only getting 500ft from my house wasn't a good way to start the relationship with my bike. Although I'm thankful I wasn't on the freeway when it happened. I will be taking her apart soon and let you know what I find. But in the meantime, anyone have ideas on what could have caused the transmission to fail like that?
-Danner
Not that it will come to it, but in-case you have to take the trans apart- no fear! its quite easy to do.
Edit: saw the pictures. Thats a total downer. I would like to know what caused this? Broken timing chain? Interested to see what the engine looks like with the crank-case cover off.
Best of luck! :2thumbup:
  • Northern California
  • 1984 K100
Mr. Creative
« Reply #27 on: May 24, 2016, 08:01:18 AM »
I took apart watches when I was a boy. I had a box full of parts. That was easy, too. I had to buy one with my allowance when I wanted one that worked.
  • 1995 K75 89,000 miles
Offline jjs1234
« Reply #28 on: May 24, 2016, 09:56:12 AM »
Yes it's easy to take something apart and not be able to put it together again... I did this when I was very young too. Telephones, really old computers etc.
As far as the trans goes the most difficult part is only if  you forget where the shims go.
  • 1984 K100
Mr. Creative
« Reply #29 on: May 28, 2016, 03:07:30 PM »
Looks like I may have been right about the thrown rod.  Did you look to see if the oil pressure sender was didsconnected?   Have you contacted the seller yet to see if he will give some compensation?
With the price of used engines what they are,the good news is that you should be able to part out your old one for a good chunk of what the replacement will cost.  Or have a nice supply of spares for cheap.  Too bad this had to happen at the start of the riding season.
Offline danpalooza
« Reply #30 on: May 29, 2016, 12:07:45 AM »
The oil pressure sensor was connected. But I took the crankshaft cover off today. Turns out the connecting rod snapped. Any ideas how this could have happened? it did some damage.
  • Phoenix, AZ
  • 1992 K75 RT
Offline jjs1234
« Reply #31 on: May 29, 2016, 12:09:38 AM »
I forget but somebody on here had me check my rods if they were bent. Hydrolock?
Wiki:
Hydrolock (a shorthand notation for hydrostatic lock) is an abnormal condition of any device which is designed to compress a gas by mechanically restraining it; most commonly the reciprocating internal combustion engine, the case this article refers to unless otherwise noted. Hydrolock occurs when a volume of liquid greater than the volume of the cylinder at its minimum (end of the piston's stroke) enters the cylinder. Since liquids are nearly in-compressible the piston cannot complete its travel; either the engine must stop rotating or a mechanical failure must occur.
  • 1984 K100
Mr. Creative
Offline danpalooza
« Reply #32 on: May 29, 2016, 12:12:31 AM »
Good call Gryph, you called it.
  • Phoenix, AZ
  • 1992 K75 RT
Offline danpalooza
« Reply #33 on: May 29, 2016, 12:16:26 AM »
Wiki:
Not sure how water could get in the engine. I live in AZ, it hardly ever rains here.
  • Phoenix, AZ
  • 1992 K75 RT
Offline jjs1234
« Reply #34 on: May 29, 2016, 01:00:21 AM »
Fuel... idk foreign material in the chamber
  • 1984 K100
Mr. Creative
Offline The Dude
« Reply #35 on: May 29, 2016, 01:23:50 AM »
Thanks for showing us the insides.
Is the big end seized?The rod is twisted and broke.
  • Auckland, New Zealand
  • K75s
Current.
TR6R 1973 from new.
All the best!
Offline richarddacat
« Reply #36 on: May 29, 2016, 06:05:19 AM »
Bummer.
« Reply #37 on: May 29, 2016, 06:26:38 AM »
It's also possible that there could be a broken valve at the head end that could have caused it.
Sent from my SCH-R970 using Tapatalk
1995 K1100LT 0302044
1997 K1100LT 0302488 (R.I.P.)
Offline TrueAce
« Reply #38 on: May 29, 2016, 09:17:31 AM »
Wow. That's discouraging. Where will you plan to go from here? Bummer,indeed........sorry for your trouble.
  • Florida
Offline danpalooza
« Reply #39 on: May 29, 2016, 03:35:41 PM »
Dude, not sure what you mean by the big end. The crank doesn't move at all if that's what you mean.
Scott, I'm planning on doing a tear down to investigate further.
Ace, it was a day ruiner for sure. My plans from here is to source a new motor and make a project out it. I was thinking about turning her into a scrambler since I'll have her completely torn apart.
  • Phoenix, AZ
  • 1992 K75 RT
Offline The Dude
« Reply #40 on: May 29, 2016, 03:45:55 PM »
Yeh,terminology is terminally misunderstood."Big end"is the larger con(necting) rod bearing and runs on the crank shaft.If it is seized up it may indicate that a lubrication failure caused the con rod to snap.
This is the most likely cause,imho.
  • K75s
Current.
TR6R 1973 from new.
All the best!
Offline TrueAce
« Reply #41 on: May 29, 2016, 03:47:26 PM »
There you,go, Danpalooza, sure it's a kick in the teeth, but after you coast for a bit, jump back on that mule and make it your bitch! :clap:
  • Florida
Offline danpalooza
« Reply #42 on: May 29, 2016, 10:17:34 PM »
Dude, I'll take a look when I get the engine completely torn apart
Ace, no way I'm giving up yet!
This where I got this weekend. Hopefully next weekend I'll get the engine more torn down.
  • Phoenix, AZ
  • 1992 K75 RT
Offline TrueAce
« Reply #43 on: May 29, 2016, 10:43:19 PM »
Oh, Man, I think I just figured out what caused your problem...................sibling rivalry with a certain shiny silver Honda.
  • Florida
Offline The Dude
« Reply #44 on: May 29, 2016, 11:41:31 PM »
The motor is toast.Best concentrate on finding a next one and get back on that ride...the dead motor isn't worth mending,just curiosity as to why?I guess.
  You mentioned the crank shaft was seized.Can you rotate the bolted cap of the broken con rod on the crank?Take the cap off,even?Inspect what you reveal.
All the best.
  • K75s
Current.
TR6R 1973 from new.
All the best!
Offline danpalooza
« Reply #45 on: May 30, 2016, 12:22:41 AM »
Ace, I wasn't planning on mending it. I just wanted to see what caused the failure (as I'm sure you and other curious motobrickers do too on this thread).
 I'll try to rotate the rod on the crank to see if it can even turn.
  • Phoenix, AZ
  • 1992 K75 RT
Offline danpalooza
« Reply #46 on: May 30, 2016, 12:24:18 AM »
Ha! That's actually my dad's bike, he was helping me out with the tear down. That new goldwing is pretty sweet though.
  • Phoenix, AZ
  • 1992 K75 RT
Offline tsnap
  • recovering Polygacyclist, juvenile polycyclic disease
  • Retired Unprofessional Whacko Driver
« Reply #47 on: May 30, 2016, 08:13:53 AM »
True ACE? " There you,go, Danpalooza, sure it's a kick in the teeth, but after you coast for a bit, jump back on that mule and make it your bitch! :clap:"
This is a donkey mecca
tom :hehehe
  • Kirksville, MO
  • K1k1100 Radar Sloth1994 48K ABSII no shame wall 4 me
just plain tom, he is a dirt mean man
Offline TrueAce
« Reply #48 on: May 30, 2016, 03:03:30 PM »
Well, I say "Donkey-Wonkey"..........my people's & me always been more partial to mules, sort of runs in the family, if ya know what ah mean....
  • Florida
Offline TX brick
« Reply #49 on: May 31, 2016, 06:36:28 AM »
In the first picture that was posted I see mud on the cover and a distinct dirty line near the intake snorkel. I wonder if the bike was submerged and hydro locked?
That could have damaged the rod and it broke later.
Ron
91 K75RT
Belton Tx
