Author Topic: HELPFUL KNOWLEDGE  (Read 6337 times)
Offline BAMBAM1039
HELPFUL KNOWLEDGE
« on: May 20, 2016, 03:43:31 PM »
Im hoping someone can answer these questions  On my 1990 k1 there are 3 switches on left side of tank in fairing One says ABS one is a  triangle that looks like the red triangle  on center of gauges and one is blank? Also what does lighted triangle on center of gauges do or stand for   Thanks ahead of time for any helpful info
  • CONNECTICUT
  • PRESENT 1990 KAWASAKI ZX11 TURBO 2010 VICTORY HAMMER S 1995 K1100LT PAST RUPP BLACK WIDOW BENELLI VOLCANO 180 1975 HONDA XL250 1977 HONDA MR175 1971 HONDA SL350 1974 INDIAN 100 1976 SUZUKI TS100 1984 KAWASAKI GPZ 750 1985 KAWASAKI NINJA 900 1984 KAWASAKI NINJA900/1000 NITROUS DRAG BIKE 1990 ZX11 1992 ZX11 1986 NINJA 1000 1990 ZX750 1998 zx9 2000 ZX12 2006 ZX10 2006 ZX14
Re: HELPFUL KNOWLEDGE
« Reply #1 on: May 20, 2016, 03:50:40 PM »
greetings bambam...
the abs button is for resetting your abs...
the red triangle is 4 way flashers...
the blank is heated grips... supercharger... or nothing...
the red triangle is the bulb monitoring unit...
now go use the search box to see what the bmu does... dozens of posts here about it...
if you want to post about anything elrctrical or  mechanical or technical... you must first use the search button to acquire information... your post must demonstrate that you used the search button...
if you want to know what parts fits your moto...
1st... getts the last 7 digits of your vin and put in here to see what your moto really is...
2nd... then pick your moto here...
3rd... after you figger out the exact part number put it in here to see what all motos it fits...
4th... then put your questions in here and  search it...
5th... make your post... include the part numbers you looked up... include screen prints to demonstrate you doing the minimum...
when you do the minimum your post will stand on its merits... if you choose to not do the minimum your post will be locked and pinned up on the wall of shame...
Offline BAMBAM1039
« Reply #2 on: May 20, 2016, 03:54:12 PM »
thanks i guess flashers dont work  and why would i reset abs and what is bmu?????? thanks again  the triangle on dash goes out sometimes and stays on other times/
  • CONNECTICUT
« Reply #3 on: May 20, 2016, 04:03:28 PM »
if your abs goes whack... and if you want it to work again it must be reset... does this moto have abs...
its all right here... including bulb monitiring unit info...
http://www.motobrick.com/index.php?action=search
Offline The Dude
« Reply #4 on: May 20, 2016, 07:45:29 PM »
I soon learnt to push both indicator(flasher)paddle switches together to get all four going.Very usefull,as a silent horn!
Yeh,you probably knew that.Oh well.
  • Auckland, New Zealand
  • K75s
Current.
TR6R 1973 from new.
All the best!
