Author Topic: Trick for removing oil filter  (Read 11135 times)
Offline cmattina
« on: April 30, 2016, 12:09:10 PM »
I would assume we all have had frustrations getting the oil filter off. I had a lot of trouble finding a wrench that fit it properly...
Either way, if you are having trouble getting your wrench to fit the filter, stick a couple paper towels inside it to make it grip a little better. Seems simple, but perhaps sometime, somewhere this will help. I just did it before dropping the oil pan, and the paper towels worked like a charm!
Contact me if you need a hand in the Thunder Bay area.
Re: Trick for removing oil filter
« Reply #1 on: April 30, 2016, 12:13:35 PM »
good idea.  if it REALLY stuck a couple sheet metal screws through the cap wrench into the filter should do the trick.  Though if that doesn't work you'll probably have to drop the pan and use a hammer and chisel.
« Reply #2 on: April 30, 2016, 12:28:42 PM »
sand paper between filter and cup...
Offline pallum
« Reply #3 on: May 08, 2016, 08:38:12 PM »
I pop a nail in mine. Same nail every time and takes just a second
  • Federal Way, WA
Offline The Dude
« Reply #4 on: May 08, 2016, 11:10:33 PM »
This works,for mine.
  • Auckland, New Zealand
  • K75s
Current.
TR6R 1973 from new.
All the best!
« Reply #5 on: May 08, 2016, 11:47:55 PM »
I haven't but I don't mind feeling left out.
Offline Mongrel
« Reply #6 on: May 20, 2016, 01:48:41 PM »
Yep. I've punched a hole in mine once or twice and that'll get it out if nothing else does.
'86 K75c
Offline colly
« Reply #7 on: May 21, 2016, 07:20:56 AM »
I used the screw trick to get my old oil filter out, but when I put the new one back in I just hand tightened it - is that OK or do you need to use a special tool? It did not seem like there was enough room to really fit anything else in there.
I've also got a small oil leak at the front left - but I checked and all the bolts are tight. I did not replace any rubber or anything is it essential to do this? What should I do to fix it?
  • Ireland
  • 1983 BMW K100
Offline jakgieger
  • itinerant farmer
« Reply #8 on: May 21, 2016, 08:39:02 AM »
Depends on your hand :dunno This method should be sufficient.  As for your leak...you gotta do your due diligence :bmwsmile (pictures/further accurate description) or you gonna end up on the "can you read" WOS. :deal:  That being said, clean the affected area  ie., pan, valve cover, etc., and visually determine where the leak is from :yes.
  • Kansas USA
  • 1989 K100rs se
« Reply #9 on: May 21, 2016, 03:36:49 PM »
Clean up the engine then use spray talc, the leak will be revealed. Someone else's idea so can't take credit.
Offline petermarek
  • Bald Shins
  • Bald Shins
« Reply #10 on: May 25, 2016, 08:43:34 PM »
The end result of removing an over torqued oil filter i had to remove during my initial refurbish. Net requirement: dropped the oil pan and had to remove the sump siphon, then attack with a big hammer and a sturdy steal rod....
  • Maryland, USA
  • 1985 K100RT
I ride a K 100 RT - say good bye to leg hair after 100 miles!
Offline jakgieger
  • itinerant farmer
« Reply #11 on: May 25, 2016, 09:05:09 PM »
[/quote
That would test the patience of Job :eek:...just when you think it won't get worse :hehehe
  • Kansas USA
  • 1989 K100rs se
Offline Elipten
« Reply #12 on: May 25, 2016, 10:58:15 PM »
Good grief!
  • San Antonio, TX
  • 1990 K75RT
Offline The Dude
« Reply #13 on: May 25, 2016, 11:28:05 PM »
Good grief!
One of my greatest fears...the other one is putting it on too loose!
  • K75s
Current.
TR6R 1973 from new.
All the best!
