Author Topic: State of the Spline  (Read 11547 times)
Offline kylemb
State of the Spline
« on: April 23, 2016, 09:04:36 PM »
https://goo.gl/photos/vUeT8qLf1Ed3NaHk8
i havent pulled the transmission yet but im curious what you fine people think about the condition of these splines. photographed are the final drive, drive shaft and transmission spline. what kind of mileage is left on these buggers? what to expect?
-K
  • North Alabama
  • 88 K100 LT // 85 K100 RT
Re: State of the Spline
« Reply #1 on: April 23, 2016, 09:11:59 PM »
First, get a better driveshaft soon.
  • 1995 K75 89,000 miles
« Reply #2 on: April 23, 2016, 09:26:47 PM »
Well, I'll add this before the fine people chime in.
Transmission shaft should be replaced. Rear drive spline appears almost worn out, too. Compare with these.
If it were my bike, it'd be off the road until repaired unless I was looking for adventure+.
« Reply #3 on: April 23, 2016, 09:42:12 PM »
what to expect?
The following is what I'd expect but unlike the bike in the video, your bike's problem may be confined to just the rear units.
Offline F14CRAZY
« Reply #4 on: April 23, 2016, 10:05:30 PM »
I'd say the trans shaft looks good to me, not so much the driveshaft. The final drive looks decent
  • Grand Rapids, MI
  • '87 K75C
Offline Elipten
« Reply #5 on: April 23, 2016, 10:58:35 PM »
Drive shaft very bad condition, bevel is more or less.
2014 CB1100 DLX
2013 CB1100 Std
1990 BMW K75 RT
  • San Antonio, TX
  • 1990 K75RT
« Reply #6 on: April 24, 2016, 08:45:58 AM »
id ride it till it wont move...
Offline Elipten
« Reply #7 on: April 24, 2016, 09:22:02 AM »
Yep get every penny out of it and then send to Bruno.
Anybody know how Bruno is doing?
2014 CB1100 DLX
2013 CB1100 Std
1990 BMW K75 RT
  • San Antonio, TX
  • 1990 K75RT
Offline kylemb
« Reply #8 on: April 24, 2016, 09:58:43 AM »
Just emailed him, said he's on medical leave for the rest of the year. :\
But has any seen one of these: http://www.beemershop.com/Merchant5/merchant.mvc?Store_Code=BS&Screen=PROD&Product_Code=TRA54063
  • North Alabama
Offline Elipten
« Reply #9 on: April 24, 2016, 11:14:34 AM »
Bruno must have something very serious!  My best wishes are for him and his family.
2014 CB1100 DLX
2013 CB1100 Std
1990 BMW K75 RT
  • San Antonio, TX
  • 1990 K75RT
Offline Devil K
« Reply #10 on: May 04, 2016, 06:52:03 PM »
So if Bruno is gone for the rest of 2016 is there anyone else who can rebuild a driveshaft? Or does he have mechanics in his shop? Because my drive shaft is toast.
  • Kernville
  • 1994 BMW K75S
Offline kylemb
« Reply #11 on: May 04, 2016, 06:56:01 PM »
Check out these new aftermarket shafts. They pretty much resolve the whole dry spline by incorporating the very modification Bruno does to his refurbished splines
  • North Alabama
Offline Elipten
« Reply #12 on: May 04, 2016, 07:46:07 PM »
Where is the link?
  • San Antonio, TX
  • 1990 K75RT
Offline kylemb
« Reply #13 on: May 04, 2016, 07:47:00 PM »
The Ei driveshaft has been very popular with the R100GS riders where failure is more of a problem. Ei also has a K75/K100 driveshaft which is less known because as a general rule we don't have u-joint failures on the K models like we do on the R100GS (only spline failures typically). But it has all the features and benefits that the R100GS driveshaft is known for such as:
All parts are available separately so if you were to have a u-joint failure at some point (unlikely) you could buy just the front part and a u-joint kit for example. With a BMW shaft you have to throw it away and start over even if you only need the spline or just a knuckle for example.
The u-joints are larger than stock, very heavy duty German joints made by Elbe with grease fittings so they can be serviced.
Specific to the K model driveshaft, a closed grease canal so the female spline can be packed with grease and it will stay put unlike the factory shaft where the grease just migrates out of the spline.
These shafts are sold around the world by other BMW specialists in Australia, Germany, England and elsewhere and have withstood the test of time with proven reliability.
They are less expensive than a BMW shaft, and rebuildable so in our view it's a no brainer that this shaft is the better choice.
  • North Alabama
Offline Devil K
« Reply #14 on: May 04, 2016, 08:02:37 PM »
So essentially what you are saying is that they make a complete drive shaft that will fit on my 1994 bmw k75s that is much more reliable all around?
  • Kernville
  • 1994 BMW K75S
Offline kylemb
« Reply #15 on: May 04, 2016, 08:08:07 PM »
yes
  • North Alabama
Offline Devil K
« Reply #16 on: May 04, 2016, 08:10:52 PM »
Fantastic. Now I'm going over to the engine category to talk about pushing my motor to the next level... if it's even possible.
  • Kernville
  • 1994 BMW K75S
Offline F14CRAZY
« Reply #17 on: May 04, 2016, 08:25:11 PM »
I think it was one of the European BMW parts outlets online that sells replacement splines for driveshafts. Have to have a machine shop lop off your old splines and weld the new shaft piece with the new splines on.
Thank goodness my bike came with a spare driveshaft in good shape
  • Grand Rapids, MI
  • '87 K75C
Offline F14CRAZY
« Reply #18 on: May 04, 2016, 08:26:24 PM »
Wouldn't converting to a K1100 Paralever side arm and driveshaft and final drive fix the problem?
  • Grand Rapids, MI
  • '87 K75C
« Reply #19 on: May 04, 2016, 08:35:24 PM »
jeff lee
http://www.repro-works.com/
emeraldislandco@gmail.com
« Reply #20 on: June 16, 2016, 08:05:04 PM »
I just bought a new OEM driveshaft -- probably would have gone for the aftermarket one but I had a gift card at Bob's for $250 of the $343 it cost me. But with proper lubing it will probably outlast me - my last OEM one got chewed up primarily due to lack of maintenance -- noone's fault but mine.
I wish I had sent my toasted ones to Bruno while I had a chance. I have one of his driveshafts that came with a bike I bought last year -- amazing considering he only charged $200 for the rebuild. Here's wishing a quick and full recovery for whatever is ailing him.
