Author Topic: Rebuild, or buy a new one???  (Read 5440 times)
Offline nsarvai
« on: April 17, 2016, 09:57:23 PM »
I have a 1994 BMW K75, that I took out of storage this year, had to rebuild that caliber in the rear. I did all that smoothly then bleed the brakes. When doing this I came across a lead that I didn't know about. The master cylinder seal is leaking. After taking it for a ride the brakes hold up fine, but still leaks. I have been looking at parts and would like input. Should I get a rebuild kit for $90, or should I buy a new master cylinder for $250?
  • New Hampshire
  • 1994 BMW K75RT
Nic
My Garage,
1986 BMW R60
1994 BMW K75RT
2009 Honda Rebel
Offline TrueAce
Re: Rebuild, or buy a new one???
« Reply #1 on: April 17, 2016, 10:06:19 PM »
Rebuild kit should be all you need since you report the brake is working but leaks.
  • Florida
Offline nsarvai
« Reply #2 on: April 17, 2016, 10:07:38 PM »
Thanks,
I am going to try that... Will post back to see if all works well.
  • New Hampshire
  • 1994 BMW K75RT
Nic
My Garage,
1986 BMW R60
1994 BMW K75RT
2009 Honda Rebel
« Reply #3 on: April 17, 2016, 11:23:59 PM »
You may be able to open it up and clean it up real good to cure it......
I had my front MC not building pressure, though it wasn't leaking.
Pulled the piston out, cleaned the bore, honed it, re-assembled and all is well. Builds pressure good and firm, no leaks.
Offline nsarvai
« Reply #4 on: April 17, 2016, 11:33:21 PM »
I just ordered the rebuild kit online! I will have to take it apart and check that out before I use the lot! I just want to get out riding again! Had to take my R60 out for a spin instead today! Thanks again for the help!
  • New Hampshire
  • 1994 BMW K75RT
Nic
My Garage,
1986 BMW R60
1994 BMW K75RT
2009 Honda Rebel
« Reply #5 on: April 17, 2016, 11:48:35 PM »
Where'd you buy the kit, Nic?
Offline nsarvai
« Reply #6 on: April 18, 2016, 05:45:08 AM »
I get most of my parts from MAX BMW Motorcycles!
http://maxbmwmotorcycles.com
They are the same price as the BMW store online, but figured it's a lot closer to home for shipping! Anywhere I looked it was the same price!
  • New Hampshire
  • 1994 BMW K75RT
Nic
My Garage,
1986 BMW R60
1994 BMW K75RT
2009 Honda Rebel
