Author Topic: Conventional but unconventional- My k100 build  (Read 180333 times)
Offline jjs1234
Re: Conventional but unconventional- My k100 build
« Reply #100 on: June 04, 2016, 10:45:32 PM »
Sorry I meant paint
  • Northern California
  • 1984 K100
Mr. Creative
Offline TrueAce
« Reply #101 on: June 05, 2016, 10:22:18 AM »
So, you said it, all this work is to have a "burner" for collecting the insurance!
  • Florida
« Reply #102 on: June 05, 2016, 10:32:24 AM »
. . . and then justify to the insurance company why it's worth a lot more than market value. At least I can with my insurance.
Right. :hehehe
  • 1995 K75 89,000 miles
« Reply #103 on: June 05, 2016, 10:34:34 AM »
It's easy to buy the extra coverage.  Getting them to pay that amount on a loss is quite another story.
Offline jjs1234
« Reply #104 on: June 05, 2016, 04:28:22 PM »
I wanted to take this bike to South America. That's one reason I didn't chop the frame, so I can carry bags. I just wonder since it will be so new, if someone is going to do something stupid...
Anyway, assembled the transmission. I believe the gears are meshed correctly. Had to take it apart again because the input shaft wouldn't move, and a grinding noise.
  • 1984 K100
Mr. Creative
« Reply #105 on: June 05, 2016, 04:32:59 PM »
Like steal it or rob you because you look wealthy? That's not really stupid; that's just predators doing what they do, and we've got plenty of home-grown ones that will give you some practice before you leave.
Offline The Dude
« Reply #106 on: June 05, 2016, 04:47:00 PM »
I agree about the vein hope with the insurance.Never been insured for my own bikes,just for third party but I'd be the one coming off worse any way.I use my own.Its far quicker at resolving issues!
You will need to provide your own also,that is continual vigilance with situational awareness.Especially if you go off the beaten trail.
  • Auckland, New Zealand
  • K75s
Current.
TR6R 1973 from new.
All the best!
« Reply #107 on: June 05, 2016, 05:00:14 PM »
Before you head south, spray your bike with a PlastiDip mixture that resembles mold and carry your gear in these—already translated into Spanish and Brazilians will get the picture, too.
« Reply #108 on: June 05, 2016, 05:09:41 PM »
Now that I've really looked at those bags, I'm considering painting my tragkorbs red and lettering them similarly.
Offline bocutter Ed
« Reply #109 on: June 06, 2016, 07:54:53 AM »
Are the shims back where they came from, or did you mix them up?
  • Toronto, Canada
Offline jjs1234
« Reply #110 on: June 06, 2016, 09:35:14 AM »
I believe them to be in the correct spot.
When installing the gears, they need to be flush with the rear side of the case. Thus it is my understanding that the shims just help the gears to be secure in the case, when the front cover is added.
 I don't believe they have anything to do with preloading like on a rear differential.
It is my understanding that you cannot add shims to the rear of the transmission. Only to the front.
  • 1984 K100
Mr. Creative
Offline bocutter Ed
« Reply #111 on: June 06, 2016, 09:18:09 PM »
I had my trans apart to replace the snapped gear selector shaft. Was ready to button it up when a bud dropped by ... "Can I see inside?". The shims landed on the bench. Turns out they're not necessarily the same thickness ...
  • Toronto, Canada
Offline jjs1234
« Reply #112 on: June 06, 2016, 09:19:06 PM »
Correct. Do you remember which ones whent where?
  • 1984 K100
Mr. Creative
Offline bocutter Ed
« Reply #113 on: June 06, 2016, 10:18:58 PM »
I think it would be different in each trans. Lay a straight edge (steel ruler thingie) across the face of the case and measure down to where the shim(s) sit on the shaft. When shimmed both should measure the same.
  • Toronto, Canada
Offline jjs1234
« Reply #114 on: June 07, 2016, 10:02:18 AM »
Will do. Thanks! I'm thinking it may have been hard to shift due to lack of lube. We will see...
  • 1984 K100
Mr. Creative
Offline jjs1234
« Reply #115 on: June 08, 2016, 09:23:14 PM »
Waiting on the shift footpeg powder coat before I can test and complete the gearbox and then put it on the bike.
In the meantime I got these two little cool things. Going to add the Molly 2 the engine oil and gear oil. I have replaced every seal.
Bep 2.0
  • 1984 K100
Mr. Creative
« Reply #116 on: June 08, 2016, 11:13:59 PM »
I would avoid using molybdenum additives in the engine oil.  The starter's sprag clutch requires there to be some friction to operate properly.  On my K100RS the molybdenum assembly lube I used on a cylinder head job got into the engine oil and prevented the sprag clutch from engaging.  Only after an engine flush was I able to get it working properly again.
Offline The Dude
« Reply #117 on: June 08, 2016, 11:56:33 PM »
+1 for being overly protective.Its an understandable sentiment though.
Lubrication technology is very advanced,"now".More about changing these regularly,to remove the dilutants like fuel or ,if dino,chewed up molecular chains through shear,so modifying the original viscosity.
  • K75s
Current.
TR6R 1973 from new.
All the best!
Offline jjs1234
« Reply #118 on: June 09, 2016, 11:20:26 AM »
have you had any issues with full/partial synthetic oil?
  • 1984 K100
Mr. Creative
Offline Elipten
« Reply #119 on: June 09, 2016, 12:51:44 PM »
Synthetic is the way to go, but avoid the moly additive to the engine.
  • San Antonio, TX
  • 1990 K75RT
Offline jjs1234
« Reply #120 on: June 14, 2016, 01:22:19 AM »
Today:
  • 1984 K100
Mr. Creative
Offline jjs1234
« Reply #121 on: June 14, 2016, 08:32:25 PM »
  • 1984 K100
Mr. Creative
Offline The Dude
« Reply #122 on: June 14, 2016, 10:30:55 PM »
Wow?
  • K75s
Current.
TR6R 1973 from new.
All the best!
Offline jjs1234
« Reply #123 on: June 14, 2016, 11:34:13 PM »
What's with the ? Hah I need to scrape off the red on the Brembo logo
  • 1984 K100
Mr. Creative
Offline The Dude
« Reply #124 on: June 14, 2016, 11:42:31 PM »
Wow?!?!?
JJS 1234 you go for it.
Keep us posted....
  • K75s
Current.
TR6R 1973 from new.
All the best!
