Author Topic: Emergency Flasher Switch Install  (Read 2373 times)
Offline White Dog
« on: April 15, 2016, 10:24:26 PM »
Using the Clymer manual as a guide, I successfully replaced my defective flasher switch with a new one today.  It was a little tricky getting the plug threaded thru the triple tree area, but a calm mind helped me through this.  I used a string to serve as a routing guide for the wiring.  The plug was buried in some other wiring under the gas tank, so a partial removal of the tank was necessary.  On my K75 I moved the tank to the left side of the cycle.  I recall reading someone moved his to the right-hand side to work on wiring underneath.  I made sure my wiring colors matched on both sides of the connector.  Attaching a hot wire to the ground side would not be good.
  • Basement Garage
  • '95 K75 ABS.
'95 K75 ABS Red
'96 R1100RT Burnt Orange
2008 Goldwing Black
2014 CB1100 Std. Black
Reside in NC
