Author Topic: I am toying with the idea of removing the tupperware  (Read 37717 times)
Offline beemrdon
« on: April 14, 2016, 09:23:12 PM »
I don't think I'd call this a "project" but I am toying with the idea of removing the tupperware from my K 1100 LT and adding a wind screen.
The bike is really hot in the summer and that's when I want to ride most. Removal of the fairing should alleviate most of the heat issue, hopefully.
I know I will give up some cold weather coverage, but, unfortunately, can't have it both ways. This bike will remain a touring machine.
I will also most likely swap to a "C" type handlebar.
Questions:
What headlight will fit? And what is readily available at a decent price-point?
Any suggestions on decent coverage wind screens?
I will also need turn signals.
Anything else?
Offline Scud
Re: I am toying with the idea of removing the tupperware
« Reply #1 on: April 14, 2016, 09:47:53 PM »
Can a K75s fairing fit on K100? I find the K75s to be a very nice mid-size fairing that I can get behind if I want to - or air out a bit if I want to.
Pretty soon I think I'll be able to offer up a complete fairing with all brackets (but no windshield). But I see Beantown in your signature, which I assume means Boston - and I'm far away, so shipping would be costly.
Anyway, I am still curious about whether the K75s fairing could bolt on to a K100.
  • Carlsbad, CA
Offline beemrdon
« Reply #2 on: April 14, 2016, 09:53:42 PM »
Scud, I would think so but I am no expert.
« Reply #3 on: April 14, 2016, 09:56:23 PM »
The 1100's are probably a little different then the 75's but have a look here anyway: http://www.motobrick.com/index.php?topic=3186.0
Offline beemrdon
« Reply #4 on: April 14, 2016, 10:26:20 PM »
Thanks for the link Tim. Good info.
Offline Scud
« Reply #5 on: April 14, 2016, 10:29:51 PM »
+1
The bigger radiator on K100 would probably prevent an easy bolt-on of a K75s fairing.
  • Carlsbad, CA
« Reply #6 on: April 14, 2016, 11:17:39 PM »
back in '05 a deer hit destroyed  my K75s fairing.  Bike was ok, rigged up some home made brackets and a Maier sport fairing, using the original headlight. Not as much wind or rain protection but otherwise very good.   In 2012 I found some "S" bodywork with a horrid paint job, hence the cameo paint the bike now sports.  Revzilla still has them for $128, looks like a duplicate of an early GPZ550.
Offline beemrdon
« Reply #7 on: April 14, 2016, 11:25:43 PM »
I think BMW made or sells a windscreen that was optional for a naked K100 back in the day but I'll have to research it. I would probably go in that direction as I will want to take it off from time to time. A fairing is not easy to take on and off.
I took the frame mounted Luftmeister fairing off of my R90/6, 7 or 8 years ago and bought a windscreen. I occasionally ride w/o the screen...and it is fun.
Offline beemrdon
« Reply #8 on: April 14, 2016, 11:27:51 PM »
Chaos, That little fairing looks pretty good.
Offline beemrdon
« Reply #9 on: April 14, 2016, 11:42:06 PM »
Anyone know where I can get a high quality round H4 headlight (complete) ? Or would a BMW breaker be a better choice ?
« Reply #10 on: April 15, 2016, 12:11:01 AM »
Don there used to be a guy in the BMWMCQ who fitted a K75s fairing to his K100, this was over 10 years ago. I will try and track it down and post what I find. I did talk to him about the conversion and I seem to remember that it fitted  with slight easy modifications as long as you had all the mounting hardware. The only omission was the K75s belly pan. It looked like a OEM K100s.
« Reply #11 on: April 15, 2016, 12:30:03 AM »
Don tried looking at old pictures around that date but could not see any of that bike. You might have success if you email the club ( BMWMCQ ). The bike was either silver or light blue metallic from memory. Somebody should know his name and contact details. I remember talking to him about how he got his engine so clean and shiny, He used Sunlight soap and stainless wire wool.
« Reply #12 on: April 15, 2016, 12:41:53 AM »
Here are some photos of my bike before I stripped it naked.  The top of the screen was six inches below my line of sight and it provided good rain and cold weather protection. It has a simple four-point attachment—two top struts clamp to the bar, two lower mounts clamp to the tubes. I think many aftermarket screens are mounted like that. It didn't vibrate or have any other bad habits. It's stored on a rack in one of our sheds. I discovered I just liked to ride in the breeze even if it means wringing out my leathers after a rainstorm, or peeling a turkey vulture off them occasionally. I traded the Corbin Dual Canyon in that photo for a stock seat so I could change up riding position when I felt like it. I took off that handlebar, too and replaced it with a C-bar. I'm now replacing that C-bar with a lower and wider sidecar bar.
« Reply #13 on: April 15, 2016, 12:54:31 AM »
MaxBMW still lists them and all attachment hardware in their parts fiche, Don.
« Reply #14 on: April 15, 2016, 01:28:02 AM »
Have you considered just removing the lowers and swapping for a lower RT screen without the wings?  I've heard of riders doing that to reduce the heat behind the fairing.   That route would cost a lot less and be easily reversible when the weather gets cooler.  With a couple old knee panels to cut down you could still use the glove boxes and it would give a bit more finished look.
I don't know how you would do it on an 1100, but I installed a fuel cooler in front of the engine on my K75RT and by not pumping boiling gasoline back to the tank I have found that riding is a lot cooler in the summer.
« Reply #15 on: April 15, 2016, 01:53:03 AM »
that windshield on Laitch's bike is a Plexistar 2, still available, I have one on my Ural and it give great cold weather protection.  Comes on or off in a couple minutes once you get it mounted.
« Reply #16 on: April 15, 2016, 11:22:20 AM »
motocycles are supposed to be really hot in the summer... period...
Offline beemrdon
« Reply #17 on: April 15, 2016, 11:26:10 AM »
Thanks folks,
A lot to think about. I thought that wind screen on Laitch's bike looked familiar. I have that on my R90/6. It works good and comes off quickly. It's fun to ride it bare when the weather is agreeable but I'm happy to have a screen in the rain, esp when riding with an open face helmet.
Has anyone seen an S fairing on a K? I think that might look (and work) pretty K-ool.
I remember seeing the old K 100 bikes w/o any fairing years ago and pictured my bike like that but I would need to find a new place for the fuel and temp gauges to reside.
....maybe this IS a project after all.
I'm going to try some of the insulating tricks posted online here and elsewhere for this summer and then make a decision in the fall based on how well they work or don't.
« Reply #18 on: April 15, 2016, 11:33:42 AM »
If anybody wants that screen they can ride up to our place and I'll give it to them gratis. PM me. Don't bother washing your car until you get back home.
Offline beemrdon
« Reply #19 on: April 15, 2016, 11:36:02 AM »
Hi Johnny,
I don't think they have to be. For example, My R90/6 w/o a fairing throws no heat on me at all but I know of others with the same motor with an RT/RS fairing that complain about being blasted from the heat being generated by the motor. I guess that's where multiple bikes being set up differently is optimal. I am not saying that I will de-fair my K1100 though. It is a beautiful bike, to me anyway.
But I am thinking about it. The heat last summer was brutal, esp on the left lower leg.
Another solution would be to purchase a naked K to ride during the height of the summer heat but that is a last resort.
« Reply #20 on: April 15, 2016, 12:34:30 PM »
Oh, c'mon now.  It's a better than excellent excuse to get another brick.  Why not buy an S fairing with a K75 attached to it?  Seems to be a few popping up like daffodils this spring.   Been seeing some nice ones on C-List.
Offline beemrdon
« Reply #21 on: April 15, 2016, 12:45:43 PM »
You're right about it being an excellent excuse though. The problem is where do I put them....?
« Reply #22 on: April 15, 2016, 12:49:25 PM »
They really don't take up that much room.  I have three in the space of one car in my garage.
Are you married?  You can always park the wife's car outside.   :eek:
Offline beemrdon
« Reply #23 on: April 15, 2016, 07:57:15 PM »
Not married (anymore) and may soon be moving so new MC purchases are OUT for now.
Offline F14CRAZY
« Reply #24 on: April 15, 2016, 09:11:54 PM »
You know I've seen Gold Wings with vents in the windshield. Could one of those provide some cooling in the cockpit?
  • Grand Rapids, MI
  • '87 K75C
