Author Topic: sprag clutch issues  (Read 5918 times)
Offline jessez
sprag clutch issues
« on: April 10, 2016, 10:42:04 PM »
Just thought I'd generate some hope to people who are in a similar situation:
I lost my last bike (92 K75s) to a ruined sprag clutch.  I heard it grinding on ignition for a few weeks until I figured out what it was, then it was too late.  My local BMW guys explained that a repair for this would cost nearly the worth of the bike.  I sold it, and then got a 95 K110rs.  After a few months, I had another (what I think) sprag clutch problem.  This time it didn't grind, just intermittently would not make contact (just a whirring noise with no engagement).  I began to justifiably freak out, but reread the threads on sprag clutch issues.  Long story short, I changed the oil and added seafoam to the crankcase as soon as possible, and I've been issue free for a few months.  Literally, the problem went away.  Just passing it on so that others out there don't go through the same nightmare I did.
Re: sprag clutch issues
« Reply #1 on: April 10, 2016, 11:04:29 PM »
 :clap:
Thanks for posting this!
« Reply #2 on: April 10, 2016, 11:49:17 PM »
Really glad to hear it worked for you.  :2thumbup:
« Reply #3 on: April 11, 2016, 12:17:31 AM »
Another thread here had success carefully drilling a hole through the case to lube the sprag directly.
Offline Conrad325i
« Reply #4 on: April 24, 2016, 11:43:56 PM »
I drilled the hole and tapped it for an npt allen plug then changed oil and put seafoam. To start the bike the first two or three times i had to tap on the sprag housing thru my hole and spray WD40 in the lube hole. After this and seafoam it became reliable.
  • 1986 K75C
-Isaac
The Hills and Valleys of East Tennessee
Offline jjs1234
« Reply #5 on: April 27, 2016, 02:56:49 AM »
This is it, right? On the left
  • Northern California
  • 1984 K100
Mr. Creative
« Reply #6 on: April 27, 2016, 06:39:55 AM »
Correct, jjs.  The object at the far left in that picture is the sprag clutch.  The other objects in the picture are alternator drive dog and starter motor idler gear.
