Author Topic: Can't get my '83 Brick started. Help!  (Read 19692 times)
Offline colly
« on: April 08, 2016, 04:46:33 AM »
I just bought a 1983 K100 which had been off the road for 3 years. The guy told me it had been running when he took it off the road. I changed the oil and oil filter, drained the gas out of the tank, put in a  new fuel filter, and put in a new Odyssey battery. The bike would turn over but it would not start. I can hear the fuel pump whirring loudly. A few times it could 'chug' once or twice as if it was about to start but it didn't.
Last night we changed the spark plugs but still nothing. We checked they were sparking and they were wet so it is getting fuel. We then took out the injectors and gave them a good clean. We cranked it when they were out to verify they were spraying ok. Putting everything back together - and then when we try to start it - it often 'chugs' the first two times but not much after that.
I've just seen post 1,2 and 3 on No Start so I'll try that - but from the above does it sound like it could be anything else?
Edit: This is a video of the injectors - do they look ok?
  • Ireland
  • 1983 BMW K100
Offline spray____
Re: Can't get my '83 Brick started. Help!
« Reply #1 on: April 08, 2016, 05:31:17 AM »
Sub'd.
I'm helping colly work on the bike with a few other friends.
  • Dublin, Ireland
  • 2006 ZX-10R
« Reply #2 on: April 08, 2016, 08:14:18 AM »
greetings spray_____...
who are your friends...
o'haras smithwicks porterhouse beamish kilkenny harp murphys and the blarney sisters...
Offline colly
« Reply #3 on: April 08, 2016, 08:45:35 AM »
We'll be celebrating with all of those once we get her started Johnny!
For now, any other ideas on what to try??
  • Ireland
  • 1983 BMW K100
« Reply #5 on: April 08, 2016, 09:01:44 AM »
I had a similar problem this Spring after working on my K75.  Turned out it was a connection under the tank for the ignition.  Took me a long time to find it because even with it disconnected I was getting a spark, but it wasn't strong enough to fire under full compression.  As a result, I would get a pop or chug on the first spark, but nothing after that.
Offline colly
« Reply #6 on: April 08, 2016, 09:46:40 AM »
Thanks Guys - Johnny I'll have a look through that chart, thanks.
Gryphon, i really hope it's this simple. I'll take the tank off and look for this connection, will it be obvious?
  • Ireland
  • 1983 BMW K100
« Reply #7 on: April 08, 2016, 11:17:24 AM »
Yes. Just trace the wires from the switch down to the harness.
Offline TrueAce
« Reply #8 on: April 08, 2016, 12:05:30 PM »
There is a small four-pin connector linking the tank to the bikes wiring. It provides power for the fuel pump and sending to the fuel level lights. If the pump is working you are connected. 1)Check your starter relay with a meter to see if you have output voltage. 2) Try starting with the clutch pulled in and side stand retracted.
  • Florida
Offline colly
« Reply #9 on: April 27, 2016, 01:39:17 PM »
Hi again, I was away for a while however today we finally managed to try working on the bike again. I followed the sticky instructions 1,2 and 3, cleaned all the connectors and the ground. Tried it again and it definitely was better, however when I sprayed in the easy start - she fired right up. I was delighted! Only problem is she dies a few seconds later. Managed to do this a few times but it would not keep running. Once we heard a big of a bang and some smoke rose from the engine, not sure why.
Tried many times more, at one stage I was able to get it running without the Easy Start, on what seemed like incredibly low revs, it turned over for good few seconds just gurgling slowly,but then it would cut out.
So I'm guessing a fuel problem. Can anyone give me some pointers?
  • Ireland
  • 1983 BMW K100
Offline TrueAce
« Reply #10 on: April 27, 2016, 01:48:16 PM »
Check the tank output fuel line to be sure the fuel pump is pumping fuel to the injector rail. Maybe the fuel pump hoses aren't routed properly...........sounds like the motor isn't getting adequate fuel to run.
  • Florida
« Reply #11 on: April 27, 2016, 03:17:25 PM »
id keep it on a battery tender while messing with it... low power can cause all kinds of wack too...
Offline colly
« Reply #12 on: April 27, 2016, 04:09:17 PM »
Battery was freshly charged so I don't think its that. It's starting when spraying No Start in the airbox but won't run so its a fuel issue, I'm just not sure what exactly. Fuel pump I can hear whirring quite loudly. I checked the injectors already I think they are OK. What else could it be?
Ok thanks what should I do to test this exactly?
  • Ireland
  • 1983 BMW K100
« Reply #13 on: April 27, 2016, 06:04:05 PM »
Check for the correct spark plug lead connections to the coils—Section 3 in the image of text from the Haynes Manual on this site in the Technical Library.
Offline TrueAce
« Reply #14 on: April 27, 2016, 06:38:20 PM »
To check fuel supply, be sure the two hoses on the right forward side of the tank are hooked to the proper stem. The hose which shoots gas out under strong pressure should be routed to the fuel injectors. Your pump may be running, but it's output may not be to the correct hose. You only got two choices for plugging hose to spigot. Duh, also, do this somewhere you ain't gonna ignite gas!
  • Florida
Offline tsnap
  • recovering Polygacyclist, juvenile polycyclic disease
  • Retired Unprofessional Whacko Driver
« Reply #15 on: April 27, 2016, 07:06:55 PM »
I have been known to spend a couple hours on a bike that showed a spark  at the plug but would not run.  New plugs, WHAMMO.
mouses in the airbox?
Really, the topic Johnny suggested is the way to go.
The human always wins these encounters.
Please recycle the refreshment containers....um I mean refill
tom
  • Kirksville, MO
  • K1k1100 Radar Sloth1994 48K ABSII no shame wall 4 me
just plain tom, he is a dirt mean man
Offline Elipten
« Reply #16 on: April 27, 2016, 07:35:46 PM »
Check air box
Is fuel old?
Is there water in gas tank?
Change fuel filter
Open tank cap and while cranking look for leaks from hoses and connections
Check routing of fuel lines
Check pressure to fuel manifold
Check injectors are spraying
Good luck
2014 CB1100 DLX
2013 CB1100 Std
1990 BMW K75 RT
  • San Antonio, TX
  • 1990 K75RT
Offline tsnap
« Reply #17 on: April 27, 2016, 07:53:37 PM »
When I replaced my Porsche injectors, they would never squirt like a squirt gun and leave a "spot".  The shot like the finest perfume atomizer u have ever seen.  You actually had to look for the mist it was so fine.
It's the gaseous state that explodes well, not the liquid state.
tom
  • Kirksville, MO
Offline tsnap
« Reply #18 on: April 27, 2016, 08:06:19 PM »
on rebuildable injectors, I remove the round seals, which probably will break if old, soak them overnite in acetone, covered with foil to prevent evaporation, agitate and toothbrush,  blow out with air,  then replace the rubber rings and check them on a battery with fuel.  The mist should be incredibly fine and just almost dissipate into the air. (no smoking)
tom
  • Kirksville, MO
Offline colly
« Reply #19 on: May 04, 2016, 01:09:59 PM »
Thanks for all the replies everyone. Have been too busy to work on the bike but we are going to have another look at this tomorrow night - I will test all the suggestions given. I hope it's something simple like the fuel pump.  I'm told its common for them to fail when the bike has been sitting for a few years.
One question. From watching videos online of K100's starting, my bike makes a strange noise sometimes that I have not heard from other bikes - you can kind of hear it at the very end of theses videos: https://dl.dropboxusercontent.com/content_link/XdYQcPNzzelpfxGlRg1RnfprBvGA9qeM4FXW4h1rn6TOImYp6PeuXigWpqKdWEpl/file
https://dl.dropboxusercontent.com/content_link/E98NmIKLH86ZL19DcwpY2b3W6idtYoutv4O3olISagzWpFjbe8ToStc326AtVHhg/file
It happens after the bike cuts out. I assume this is the fuel pump. Does it sound normal? If it's making the noise is it ok, or could it still not be working properly? I found one on ebay so ready to buy but tomorrow I'll test the pressure to see what it's like.
Here is a video of when we managed to get it to tick over a little: https://www.dropbox.com/s/vjrg3zbomb4cx90/2016-04-27%2014.14.40.mp4?dl=0 - I'm not sure why it was able to do this that one time.
  • Ireland
  • 1983 BMW K100
« Reply #20 on: May 04, 2016, 01:16:21 PM »
The first two links give me error messages. In the last link, the whine when it cuts out is typical.
Offline colly
« Reply #21 on: May 06, 2016, 06:58:22 AM »
We tested the fuel pump last night and there was almost no pressure in it. Ordered a new one so fingers crossed it will be ok when I fit it!
  • Ireland
  • 1983 BMW K100
Offline colly
« Reply #22 on: May 13, 2016, 04:57:24 AM »
Got her started! :) It was the fuel pump. Delighted - now the fun stuff can start.
She's still running a bit rough though - she can take a while to start sometimes  and the revs bounce around you have to keep revving or play with the choke, sometimes she'll cut out if  left idle. What would this be and what should I do to get her running more smoothly?
  • Ireland
  • 1983 BMW K100
« Reply #23 on: May 13, 2016, 06:34:27 AM »
sounds like it just needs lotts of miles and lotts fuel injector cleaner in the tank...
way to stick with it...
now go getts you some yeeehaaaaa...
Offline jakgieger
  • itinerant farmer
« Reply #24 on: May 13, 2016, 08:07:24 AM »
Congrats on getting the bike running.  Next thing is to watch for an air intake leak.  The rubber parts have a fair amount of age.  If you search here :bmwsmile there are numerous descriptions of how to diagnose and find intake leaks.  You may not be to this point yet, but if you do not like how your injectors are performing after you attempt cleaning, several here, including me, have upgraded to a 4 hole injector from Osidetiger on ebay.  ebay.com/itm/1983-92-BMW-K100-K100RS-K100RT-K100LT-Fuel-Injectors-Best-Upgrade-4-Hole-Spray-/191863273863?hash=item2cabf13987:g:Cr8AAOxycmBS6PL9&vxp=mtr
  • Kansas USA
  • 1989 K100rs se
