Author Topic: Clutch is shuddering in first gear  (Read 5084 times)
Offline ed3541
« on: March 31, 2016, 11:02:14 AM »
I'm refurbishing an '85 K100. Swapped out the engine and tranny for a newer engine (55k) from another '85 K100. But the bike shudders when I take off in first gear. The engine seems to be running smoothly and the bike runs OK once it's going. I'm wondering if I should replace the clutch. It's too bad I didn't do it before I installed the engine. Is this shuddering when starting-out in first gear a sign of a bad clutch? If anyone has any ideas on this problem, I'm open to them.
thanx,
Ed
  • Boca Raton, Florida
  • '92 K75s '95 K75 '85 FYK100
Offline Uhtread
Re: Clutch is shuddering in first gear
« Reply #1 on: April 15, 2016, 11:07:08 AM »
Probably a bad clutch.  An old standby clutch test is to put the bike (vehicle) nose on to an unmoveable object - large tree, e.g. - and operate it as if to take off.  The engine should die.
  • Central Texas, USA
  • 1993 K1100LT
« Reply #2 on: April 15, 2016, 11:18:15 AM »
greetings ed354...
march 31st post... musta missed it...
anyway... im betting it just needs to be ridden... getts out there and commence to whacking the throttle in all gears... its a 50/50 chance it just needs some heat cycles to smooth out...
« Reply #3 on: April 15, 2016, 11:45:03 AM »
greetings ed354. . .
. . . getts out there and commence to whacking the throttle . . .
:2thumbup:
Offline ed3541
« Reply #4 on: April 16, 2016, 10:45:21 PM »
OK thanx Y'all for the ideas. I'll definitely try 'em before replacing the clutch.
Offline mr_10brook
« Reply #5 on: April 18, 2016, 07:50:52 AM »
I agree with Johnny.  I bought a 97 LT last year from Alabama with only 18k miles over the phone.  When I got it home (trailered), I had a clutch shuddering issue on taking off.   The problem went away after a few hundred miles of back and forth to work.
97 K1100LT  93 K75S x 2
95 K1100RS and 92 K100RS in same week both broken! WTF
91 K1 Black
Offline ed3541
« Reply #6 on: April 18, 2016, 10:17:22 AM »
I'm glad to hear this from 3 brick bikers now. I'm gonna go down to the DMV and get a plate so I can put some miles on it.
thanx
