Author Topic: Battery levels?  (Read 7375 times)
Offline ChristSFP
Battery levels?
« on: March 11, 2016, 07:52:17 AM »
First off, thanks for all the help so far!
Now on to the question,
So my build is almost completed (hopefully) but since I dont have the charge light on my bike anymore.. Iīm abit afraid that the batteru isnīt charging..
To the maiden trip today.
The bike read 12,43V (with engine off) before I started it up and left for my ca 20km ride..
Got back home.
13,14V with engine off.
11,96V with engine on.
Question is.. Am I good to go? Or is there anything else I can check to see if the battery is actually charging?
  • Sweden
  • K1100RS
At the moment in my garage..
BMW K1100RS - 1994
Harley Davidson Nightrain - 2007
and before this.. I had maaany other motorcycles ;)
Offline tsnap
  • recovering Polygacyclist, juvenile polycyclic disease
  • Retired Unprofessional Whacko Driver
Re: Battery levels?
« Reply #1 on: March 11, 2016, 08:42:07 AM »
Is the light system on at rest, and while running, or do you manually turn them on?  what about other acessories, stereo, gps, seat/grip heat?
if none of these, sounds like it might be ok if all connections and wiring are good.  I would put a little needle type ammeter/voltmeter somewhere in the circuit, at least for the next ride.
An  indication is if the headlight dims at idle and increases significantly at increased RPM.
tom
  • Kirksville, MO
  • K1k1100 Radar Sloth1994 48K ABSII no shame wall 4 me
just plain tom, he is a dirt mean man
Offline ChristSFP
Re: Battery levels?
« Reply #2 on: March 11, 2016, 08:47:19 AM »
Dont understand the light question.. I usually keep the light switch in the same position even if bike is running/not running?
Nothing is kept on the bike.. LED around all turnsignals plus taillight.. no heat anywhere.. no extra weight ;)
A amp meter is a good idea =) Might be worth the extra weight it puts on ;)
No dimming on lights except some small dip when the ignition strikes but thatīs common I guess.. has the same on my Harley
  • Sweden
  • K1100RS
BMW K1100RS - 1994
Offline tsnap
Re: Battery levels?
« Reply #3 on: March 11, 2016, 09:52:46 AM »
I'm thinking you are good to go. :clap:
tom
  • Kirksville, MO
Re: Battery levels?
« Reply #4 on: March 11, 2016, 10:07:45 AM »
Do it! Having it may prevent your letting the battery discharge to an extent that leaves you stalled along the highway during rush hour with a burned-out starter relay.
Re: Battery levels?
« Reply #5 on: March 12, 2016, 01:08:30 AM »
Did you replace the charge light with a pair of 56 Ohm resistors attached to the blue wire leading to the alternator?  If not, your alternator is probably not operating.  Schematic of the connection:
Offline Brad-Man
Re: Battery levels?
« Reply #6 on: March 12, 2016, 07:40:52 AM »
I believe that a voltmeter would be a better choice for everyday use.
An ammeter will show the rate the battery is charging or discharging.
A voltmeter will tell you what voltage is present.
A voltmeter will give you indication of a bad battery/dead cell -  an ammeter won't.
Note this applies to vehicles w/alternators.  I honestly don't know if an a meter is better than a voltmeter for vehicles w/generators...
No modern carmaker puts an ammeter in their cars.
Probably because of fire hazard and the weight/gauge of wire needed - the beancounters had a win-win.
JMHO..
  • Marietta, GA
  • '85 K100
'74 RD350
Offline ChristSFP
Re: Battery levels?
« Reply #7 on: March 13, 2016, 07:20:03 AM »
Hi, yes I have a resistor installed, not a pair though. Found one that seems to work
  • Sweden
  • K1100RS
BMW K1100RS - 1994
Re: Battery levels?
« Reply #8 on: March 13, 2016, 01:31:45 PM »
If you have a multimeter you can temporarily wire it up, and tape it or cable tie it to a place where you can see it easily. You can then go for a ride and see what it is doing. I have done this numerous times with cars and bikes.
Offline tsnap
Re: Battery levels?
« Reply #9 on: March 13, 2016, 03:49:46 PM »
I was going to suggest Martins tactic, but I didnt want to show how redneck shadetree I really am.  I save that stuff for when everyone has tried their methods, and then I come up with something that works.
When I was a kid, I had nearly no tools.  Used to remove vw rear axle nuts with vicegrips or a pipewrench (Stilson) (back when they could take a beating) and a 4 foot cheater bar.  Learned a lot of ways to get by without.
Built my first "motorbike" with a horizontal shaft engine and angle iron.  Had to hide the contraption, and the mower, and reverse it when Dad asked when I was going to mow the lawn.
and we lived on the last block before the bus would pick you up, so I walked over a mile to school.  Develops character, which I am!  LOL
tom
Now, with tools, I actually love to spend time wrenching.
tom :lets-eat:
  • Kirksville, MO
Re: Battery levels?
« Reply #10 on: March 13, 2016, 08:26:55 PM »
WARNING!!!  Dumb question ahead...
...why didn't you walk the block to the bus stop instead of the mile to school?
Re: Battery levels?
« Reply #11 on: March 13, 2016, 09:01:10 PM »
me me me...
cause develops character...
Re: Battery levels?
« Reply #12 on: March 13, 2016, 09:10:11 PM »
Can't even spell chracketer...
