Brake light stays on
Topic: Brake light stays on (Read 4394 times)
Donmystic1
^ Proficient Motobricker
March 10, 2016, 04:08:33 PM »
My 1985 K100rt's brake light stays on.occasionally I can shut the bike off and it will stay off on the next start. The fuklds are topped off. Is it a bad electrical connection.
Mystic, CT
1985 K100, 1985 K100RS, 1986 K100RS Turbo,1985 K100RT
Chaos
Administrator
Mars needs women!
Re: Brake light stays on
Reply #1 on:
March 10, 2016, 04:39:25 PM »
There is a little plunger switch by the front and back brake levers. One of them is probably sticking. Try squirting some silicon or wd40 on them, if lite is still stuck on unplug them one at a time to find the culprit.
sw ohio
1987 K75S VIN 0231
Donmystic1
Reply #2 on:
March 10, 2016, 05:08:34 PM »
I'll start at those two places. Thanks
Mystic, CT
Donmystic1
Reply #3 on:
March 11, 2016, 08:55:47 AM »
I meant to say the light on the dashboard not the actual brake light. It goes out occasionally.
Mystic, CT
Laitch
Faster than a speeding pullet
Administrator
Reply #4 on:
March 11, 2016, 09:11:10 AM »
Quote from: Donmystic1 on March 11, 2016, 08:55:47 AM
You probably have weak wiring to the tail light assembly bulb contacts, dirty or fractured contacts, a short in the wiring to the brake lights, weak grounding or failing bulbs, Don. I've found the monitoring unit itself to be reliable.
Along the Ridley in Vermont.
1995 K75 102,000 miles
Martin
Reply #5 on:
March 11, 2016, 04:17:22 PM »
The light on the dash lets you Know that your brake lights are being activated. It will stay on if either one of your brakes is not activating your rear light.
Regards Martin
North Lakes Queensland Australia
1992 K75s Hybrid, Lefaux, Vespa V twin.
