Author Topic: Fuel Pump WHINE!  (Read 7203 times)
Offline petermarek
  • Bald Shins
  • Bald Shins
Fuel Pump WHINE!
« on: March 10, 2016, 08:05:32 AM »
I have a 1985 K100 RT I've resurrected the summer of 2015 from a "CarPort Find".
The gas tank was clogged with dissolved rubber from the years of sitting. I cleaned it all up but had to replace the fuel pump (and all the hoses and filter). I am CHEAP, so I went with an aftermarket Bosch look alike fuel pump - HFP-437 Motorbike Intank EFI Fuel Pump ($70).  :dunno
I have nothing bad to say about the pumps reliability or durability....BUT it is so loud in the tank that it buzzes my helmet even at speed. After > 3k miles I've had it.
Thus the question: Is the OEM Bosch Pump Quiet? Do you hear it when the bike is running?
  • Maryland, USA
  • 1985 K100RT
I ride a K 100 RT - say good bye to leg hair after 100 miles!
Re: Fuel Pump WHINE!
« Reply #1 on: March 10, 2016, 08:23:35 AM »
ear plugs...
Offline tsnap
  • recovering Polygacyclist, juvenile polycyclic disease
  • Retired Unprofessional Whacko Driver
« Reply #2 on: March 10, 2016, 08:47:54 AM »
i RAN INTO A SIMILAR COST PROBLEM YEARS AGO ON A sAAB FUEL PUMP, DISCOVERED A CROSS REFERENCE TO A vw rABBIT PUMP FOR 1/3 THE PRICE.  wAS WORKING FINE WHEN I sold the car.
Heres what I found online search.  I use purolator stuff a lot.
http://www.motobrick.com/index.php?topic=2058.0
this is for a K1100, but htere is a lot of options on googling around.
tom
  • Kirksville, MO
  • K1k1100 Radar Sloth1994 48K ABSII no shame wall 4 me
just plain tom, he is a dirt mean man
« Reply #3 on: March 10, 2016, 09:20:10 AM »
if it is a 6 volt pump it will be running twice as fast...
Offline tsnap
« Reply #4 on: March 10, 2016, 09:36:43 AM »
if it is a 24 volt pump it will be running halfast.
 :falldown:
to.......m
  • Kirksville, MO
Offline petermarek
  • Bald Shins
  • Bald Shins
« Reply #5 on: March 10, 2016, 09:51:18 AM »
Ear Plugs for sure....but those are need regardless! Mines a VERY early RT; manufactured 11/14/1984!
I believe it's a 12 volt pump....I'll check - If it is 6 volt, that would explain a lot!
I did install a new BMW OEM Damper and collar with the new aftermarket pump. It seems to be isolated from touching surrounding metal mounts.
Does anyone actually have a Bosch Pump? I've read about folks having to put their ear on the tank to ensure they are getting fuel when debugging a non-start. If the extra ~$300 gets me that level of volume, I'll consider it.
I expect the normal K Bike rattles and buzzes  :bmwsmile
Thanks
  • Maryland, USA
  • 1985 K100RT
« Reply #6 on: March 10, 2016, 10:11:50 AM »
My stock bosch pump makes almost no noise.
« Reply #7 on: March 10, 2016, 10:14:56 AM »
bagster tank cover... that will block some noise...
« Reply #8 on: March 10, 2016, 10:43:33 AM »
Marshall's post has given us the benchmark for OEM performance in his K75 so here are comments eerily descriptive of your aftermarket situation, peter.
