Author Topic: Some cluster work needed!  (Read 7056 times)
Offline john11668
  • Got an ancient K100
« on: March 06, 2016, 07:04:52 AM »
Having just fixed one problem another appears !  Aint that just Typical
Just secured a front flasher and sorted a wiring issue which was probably the cause of fuse popping.
Now I find the speedo erratic. Dropping back to no reading , then maybe back up to 25 mph as I am riding along.
I will check connections  but I just want to understand how it works.
Am I right the the sensor is effectively a pulse generator  and the head contains a counter ??
Before I go digging I also want to have a look at the fuel lights, of which the red one stays on  (I  know you all think i am too fussy).
I was going to start to delve into checking probes for resistance,  but some research  in advance tells me my bike should have a float switch.
I know that the cluster has been changed , (and have reason to suspect the previous owner was no expert ) so just wondering if there could be other issues in there.
Having just had a bit of an intrusive  hernia repair job I will be grounded from riding for a couple of weeks,  so might as well make good use of the time
  • cumbria Uk
  • K100 1986
Re: Some cluster work needed!
« Reply #1 on: March 06, 2016, 08:01:42 AM »
I'm assuming your K100 is stock.  The speed sensor is located on the top of the final drive.  It is a variable reluctance (VR) sensor that detects the gear rotating inside the drive.  It outputs a low voltage (~0.5V) sine wave that has six peaks per rear wheel revolution.  The signal is fed into the instrument cluster where the circuitry inside amplifies the signal and then counts the pulses to indicate the speed.
There is a connector under the right battery cover, at the back of the cluster and within the cluster.Typically, poor connections somewhere in the path causes the signal to degrade in quality and the speedo to respond erratically.  Your investigation should concentrate on finding the poor connection and eliminating it,  by making sure all connections are clean and secure.
- remove the speed sensor and make sure it is clean (sometime iron filings gather on it)
- locate the connection under the right battery cover and clean/reseat it
- reseat the instrument cluster connector a few times to help remove any corrosion
- if these actions fail to clear up the problem, you will need to open the gauge cluster to locate the amplifier card and clean its contacts
Your 86 has a float sensor inside the tank that has a variable resistor to indicate fuel level and a switch to turn on the low fuel light.  If the light is always on, then somehow that circuit is shorting to ground. The low fuel light circuit has a connection at the tank, and at the instrument cluster.  You will need to empty the tank of gas to service the sensor because it will need to be removed.
- separate the tank connector and test resistance between the white wire and brown wire on the tank-side connector.  It should be open circuit with the float raised, and closed circuit with the float depressed.  If it always shows closed circuit, the problem lies in the sensor.
- Remove the connector from the rear of the instrument cluster.  Test for resistance between the white wire on the harness side of the tank connector and ground. If it always shows closed circuit, the problem lies in the wiring harness somewhere.
« Reply #2 on: March 06, 2016, 08:14:53 AM »
I don't think you're too fussy, john. A person who gets into the habit of ignoring red warning lights probably will ride into a world of hurt sometime or other.
« Reply #3 on: March 06, 2016, 09:03:31 AM »
If the float on the end of the gauge stem is hollow, it could have developed a pinhole leak, filled with fuel and then sunk to switch on the light. If the stem can be lifted and the light shuts off, there's a clue. This malady is probably not as likely as the connection problems explained by Robert.
« Reply #4 on: March 06, 2016, 10:21:04 AM »
Best wishes for a quick recovery on your repair job.
No, you aren't too fussy.  There is nothing worse than riding at night with that low fuel light glaring up at you.
Offline john11668
« Reply #5 on: March 07, 2016, 12:06:18 PM »
Spose I could take out the bulb and bung a gallon of fuel in the luggage box but there is something good about fixing a problem :bmwsmile
Thanks for the pointers guys.  Wiil get used to the foilbles of these machines.  Last bike I had used a spinning cable drive.
  • cumbria Uk
  • K100 1986
« Reply #6 on: March 08, 2016, 08:24:59 AM »
yes there is... riding at night with the low fuel and low weed lights on... it may be unsurvivorable...
Offline john11668
« Reply #7 on: March 31, 2016, 08:49:25 AM »
Fuel level light  now gone out .
I had a general  all around check of plugs and connectors  and light went out  . Should it self test with the ignition and then go out , or do i have to wait until the level drops to test it ?
Speedo sensor and connections checked , but speedo still reading low . It responds to road speed but reads about 25 when doing 60.
Next step please ??
  • cumbria Uk
  • K100 1986
Offline john11668
« Reply #8 on: April 03, 2016, 02:21:43 PM »
I have followed advice and cleaned a bunch of mucky connectors in the cluster but on reassembly found pin 13  loose  (only held in place by the rubber mat that surrounds all the pins. )
Now on checking I find it is a ground  pin,    but so is no. 18  !        http://www.motobrick.com/index.php/topic,8017.msg59337.html#msg59337
Will one  sound pin suffice or do I need to get 13 re- soldered??
  • cumbria Uk
  • K100 1986
« Reply #9 on: April 03, 2016, 02:30:22 PM »
You need both grounds.  Pin 13 is ground for instrument functions like tach, speedo, clock. Pin 18 is ground for instrument lights.
Offline john11668
« Reply #10 on: April 04, 2016, 05:50:37 AM »
With a bit of perseverance last night I managed to get it soldered .
There is now  continuity from 13 to 18 so they must be common rather than independent grounds .
Biggest problem was preventing solder bridging to 14  but I think I have succeeded ( no continuity) . Will soon see
  • cumbria Uk
  • K100 1986
Offline john11668
« Reply #11 on: April 10, 2016, 03:34:18 PM »
Took the bike out for a run on Saturday and all seems fine .  Speedo now reading  fine .   Thanks for all the tips .
Now I will bung a gallon  in the luggage box and ride till the red light comes on ( or not as the case may be )
  • cumbria Uk
  • K100 1986
