Drill a couple of holes in bottom of oil filter removal tool then screw self tappers through tool straight into bottom of oil filter.
Finally!!! I got the #%&$ K&N filter out. I would highly recommend not using a K&N filter on any oil head application.
There is an even more special place in hell than where the NGK plug wire guys hang and that is where I hope they send the assholes who tighten a filter like it was a cylinder head bolt.
Finally!!! I got the #%&$ K&N filter out. Had to drop the oil pan heat the filter with my heat gun and use a pair of scissors type oil filter wrench to get it off.I would highly recommend not using a K&N filter on any oil head application.
