Author Topic: Fuel injector foam protection  (Read 4147 times)
Offline Ar1100s
« on: February 22, 2016, 11:12:06 AM »
1985 k100RS There is a long rectangular foam cover on the outside of my fuel injectors. It has deteriorated. Does anyone know a generic replacement for the foam protector, or a solution to fixing it?
  • Winnetka ca.
  • R1100S
Re: Fuel injector foam protection
« Reply #1 on: February 22, 2016, 06:51:53 PM »
Interesting, I guess I've never heard of the injector rail being insulated from the factory.
I've generally uses some split foam water pipe insulation from the local home improvement store. It would be obviously thicker than what you have there, but it would serve the purpose.
1995 K1100LT 0302044
1997 K1100LT 0302488 (R.I.P.)
Offline Elipten
« Reply #2 on: February 22, 2016, 07:23:07 PM »
My K75RT had that foam, but it got hard after all the years.
  • San Antonio, TX
  • 1990 K75RT
« Reply #3 on: February 22, 2016, 09:13:20 PM »
My RT had the crusty foam and I removed it. Not an RT anymore though.
Offline Ar1100s
« Reply #4 on: February 22, 2016, 10:31:06 PM »
Thanks for all the suggestions. I appreciate it. I might just go without it.
Now back to the paint job!
  • Winnetka ca.
  • R1100S
Offline TX brick
« Reply #5 on: February 23, 2016, 06:22:47 AM »
On a side note-looks like the fuel line is cracked.
Ron
91 K75RT
Belton Tx
Offline Ar1100s
« Reply #6 on: February 23, 2016, 07:56:21 AM »
Thanks, those are all getting replaced!
  • Winnetka ca.
  • R1100S
