Author Topic: RT fairings question  (Read 5389 times)
Offline darthbane71
« on: February 16, 2016, 02:40:42 PM »
Hey guys, I have a 1993 K75RT. It is white and has some damage to the front and left side fairings. I found some fairings online and purchased them, they are in good shape and look like they'd fit, however they have some kind of adhesive like a giant sticker was on most larger spots on the fairing. I'll upload pictures as best I can. Anyone have any idea what this is or how to remove it? It also seems to have some sort of a ridge around the adhesive that I can't figure out.
http://s1378.photobucket.com/user/mike_smith46/media/Mobile%20Uploads/IMG_20160216_133116445_zpsx5w5ztpb.jpg.html?filters[user]=142553200&filters[recent]=1&sort=1&o=0
http://s1378.photobucket.com/user/mike_smith46/media/Mobile%20Uploads/IMG_20160216_133107887_zpsfpsk18qh.jpg.html?filters[user]=142553200&filters[recent]=1&sort=1&o=1
http://s1378.photobucket.com/user/mike_smith46/media/Mobile%20Uploads/IMG_20160216_133055293_HDR_zps2mkpuryj.jpg.html?filters[user]=142553200&filters[recent]=1&sort=1&o=2
  • Illinois
  • 93 k75RT, 97 Yzf600r, 80 cb650c, 81 cm400
1993 BMW K75RT
Offline Glacial
Re: RT fairings question
« Reply #1 on: February 16, 2016, 03:05:41 PM »
Your links don't work unless the reader copies the last part (after ?filters) into the browser to complete the link address.
To answer your question - I suspect that fairing was on a police or paramedic bike with big high-reflectivity panels on. I think you will need some fairly aggressive solvent to get the adhesive off.
Good luck.
  • Cambridge, UK
  • 1990 K75S VIN 0109678
Offline darthbane71
« Reply #2 on: February 16, 2016, 03:09:07 PM »
Ahhh, I did not think of the police angle. Damn. Any advice as to what product specifically?
  • Illinois
1993 BMW K75RT
« Reply #3 on: February 16, 2016, 03:29:00 PM »
I have recently had to remove Anti slip deck tape from my bikes belly pan. I used a product called Diggers Glue Rid contact adhesive remover. It's a jelly consistency, brush on and leave for 10 min wipe off and repeat, finally wash of the remains with Mineral Turpentine, then soap and water. Active ingredient 90% Xylene. You should be able to find a similar product in the US.
Offline Glacial
« Reply #4 on: February 16, 2016, 03:33:15 PM »
I have used acetone on the residue of double-sided tape before, might be a place to start.
  • Cambridge, UK
Offline darthbane71
« Reply #5 on: February 16, 2016, 03:35:08 PM »
I'm nervous using acetone. Won't that Jack up the paint?
  • Illinois
1993 BMW K75RT
« Reply #6 on: February 16, 2016, 04:10:34 PM »
I would avoid acetone and the xylene.  Not all paints resist those solvents.
I would start with mineral spirits.  Saturate a paper towel and lay it on the adhesive for a few minutes and then see if you can scrub the adhesive off.  Another option is to go to a shop that sells supplies for painting automobiles to the collision shops.   3M makes an adhesive remover that should make quick work of the mess.
http://3mauto.com/3m-adhesive-remover-03618.html
« Reply #7 on: February 16, 2016, 04:25:03 PM »
Gryph is right, while I had no problem with it softening or it effecting the paint, I was going to repaint the belly pan anyway, it might not be the best if you are not planning to repaint. If you were to use this type of remover It would be best to test first.
« Reply #8 on: February 16, 2016, 09:18:10 PM »
Try XENIT. It's citrus-based. Use a cloth and elbow grease. I've use it to remove helmet and truck decals. No effect on paint or helmet material. Spot check first. Follow the directions
« Reply #9 on: February 16, 2016, 09:29:05 PM »
Try a heat gun or even a hair dryer.
Offline darthbane71
« Reply #10 on: February 16, 2016, 09:30:41 PM »
Good idea on the heat. Didn't think of that. I'll probably try a combination of heat and some kind of adhesive remover
  • Illinois
1993 BMW K75RT
