Greetings! :euro
Just because it was zero degrees here in Vermont today doesn't mean spring won't be around the corner soon. :2thumbup:
While doing the latter half of annual maintenance on a new/old 1988 K75S today and found a few electrical issues that might be above my pay grade, but thought I'd consult you helpful cusses first.
It looks like the third ignition coil doesn't have a plug housing—it's just loose wires hanging off the plug...The others have a housing. Would that hinder any functionality or is it more aesthetics? Worth fixing? Difficult? Ordered a housing and sure I can figure it out, but wondering if might relate to other spark plug issue...
After that discovery, I decided to get the fairing off and looking at the headlight. There I noticed the plug housing behind the main bulb had one of the three plastic insertions fried (not sure if right term...). It was just the metal on that one side. The plastic seemed to have burned away. The other plastic is fine. Indication of an what? When I plugged it back in, everything worked, but the high beam wouldn't stay on. It would only come on when I pushed the light down (the flasher). Any idea how to fix that?
Is it possible to buy just a plug housing for behind the headlight? Or do I need a re-wiring of some stripe? Looked everywhere for it and couldn't find part #. Would like a stronger bulb in there anyway (currently have standard 60 watt) so maybe this is motivation to get a relay in there...
