Author Topic: Help me get my '85 k100 running again  (Read 21835 times)
Offline CCalms
« on: January 24, 2016, 05:53:44 PM »
Here's a video of the bike's current condition
Does anyone have any ideas? I really want to get out riding again!
  • Seattle
Re: Help me get my '85 k100 running again
« Reply #1 on: January 24, 2016, 06:03:38 PM »
Clean the starter as you mentioned and you probably will need new brushes in the process.  Have you gone through the electrical connections and checked that they are sound (i.e. used a good cleaner like DeoxiT)?
Offline CCalms
« Reply #2 on: January 24, 2016, 06:09:47 PM »
I've gone at the main grounding point (the one that goes to the negative terminal) with some sandpaper but that's it. I've done some basic snooping around for damaged wires and I've checked various plugs (ECU, tank connection... I guess that's it). Any advice/links on where to look? I'll get some electrical cleaner.
  • Seattle
« Reply #3 on: January 24, 2016, 06:42:40 PM »
The start motor is part of the grounding system for the electronics on the bike.  So, tackle that cleaning first to see if your symptoms disappear.
« Reply #4 on: January 25, 2016, 09:18:53 AM »
It is worth the effort to get DeOxIt.  There are contact cleaners out there that dissolve plastic.  God only knows where you're supposed to use them since almost everything has plastic in it these days.  DeOxIt is the only stuff that is definitely known to get the job done without destroying everything else.
It sounds like you may have an incorrect fuel/air mixture.  Does the exhaust smell like raw gasoline?  Have you pulled the plugs to see what they look like?  With everything you have changed so far, I think I would start looking at the sensors that send mixture control signals to the computer.  Specifically, the mass airflow sensor and the engine coolant temperature.  The problem could be a loose connector, or a bad sensor.   There are threads here that go into a lot of detail on troubleshooting these parts.
Offline CCalms
« Reply #5 on: February 06, 2016, 12:53:25 PM »
I've cleaned my starter, EFI plug, and main ground with DeoxIt. No more starter or headlight issues, but the bike still won't start. I'm tempted to spend money on new spark plugs (the current ones are not old, just dirty...) and fuel stabilizer but I think I would just be throwing away cash. There is some real issue that I need help locating.
  • Seattle
« Reply #6 on: February 06, 2016, 01:27:11 PM »
After you have tried to start it are the plugs wet or dry? With a plug removed earth it and crank it over, do you have spark?
« Reply #7 on: February 06, 2016, 01:42:27 PM »
Where is the instrument cluster?  Did the bike ever run well without It?  What is in its place?
To echo Martin here, does each spark plug emit a bright spark?
Is each spark plug connected to its correct coil fitting? How did you verify that?
Is each cylinder test port capped?
Did you perform the Hall Effect Sensor (HES) test recommended in response to your first post, or were you unable to get the bike running enough?
You've checked and eliminated certain causes by cleaning and replacing parts. An orderly measurement process seems to be indicated if sufficient spark is being delivered to the correct cylinders.
Watch this video.
Offline CCalms
« Reply #8 on: February 06, 2016, 05:38:27 PM »
Currently with full choke and no throttle the bike fires for 0.5-1 seconds and dies.
  • Seattle
« Reply #9 on: February 06, 2016, 06:03:00 PM »
The bike did once run quite well although with intermittent failures.
The instrument cluster was removed as it didn't work. I never needed to bypass anything and the bike was able to run without any cluster attached.
Just to clarify, CCalms, the bike was able to "run quite well" without the instrument cluster but had "intermittent failure." Please describe what "quite well" means and describe the intermittent failures, their frequency and their duration.
« Reply #10 on: February 06, 2016, 06:36:31 PM »
Have you tested the items that Gryphon suggested -- temperature sensor in the stand pipe and the mass airflow sensor.  Follow the steps outlined in Bert's diagnosis page  http://hrsbstaff.ednet.ns.ca/bvogel/K100/download/bike-wont-start1.htm
specifically for the temperature sensors.  Also, remove the MAF and make sure that it is operating properly, both mechanically and electrically as per Bert's guidance.  The throttle hesitation seems to me to point towards fuel starvation.  That can come about from blocked fuel delivery (all of which you have replaced except for the pressure regulator) or poor fueling (which you need to check).
Offline Brad-Man
« Reply #11 on: February 07, 2016, 08:09:01 AM »
I would definitely run a check on the AFM...
  • Marietta, GA
  • '85 K100
'74 RD350
Offline tsnap
  • recovering Polygacyclist, juvenile polycyclic disease
  • Retired Unprofessional Whacko Driver
« Reply #12 on: February 07, 2016, 03:42:18 PM »
A tip I learned years ago, when everyone insisted that I NEVER try to clean my MAF on my  multiport 1989 Z28.
When cleaning, use brake cleaner  sparingly, carb cleaner contains lube(oil that can affect heating and cooling of the sensor wire) which leaves a film.
Also , flush part in reverse, pushing contaminants out in reverse of normal air flow.
Has always worked for me, FWIW
tom
  • Kirksville, MO
  • K1k1100 Radar Sloth1994 48K ABSII no shame wall 4 me
just plain tom, he is a dirt mean man
« Reply #13 on: February 07, 2016, 05:20:06 PM »
When cleaning,  use spray cleaner designed for MAF, not carb or brake cleaner.   It is available at any auto parts store.
Offline tsnap
« Reply #14 on: February 08, 2016, 09:19:52 AM »
oops, I meant starter fluid contains cylinder lube.  But now i am getting a can of maf scrub.  thanks.
 hard for old farts to keep up with new products.  Heck, do plumbers even carry big wrenches anymore?  For some reason, my dad thought I NEEDED TO KNOW HOW TO THREAD PIPE BY AGE 8?
RECENTLY HELPED ON A SHARKBITE PROJECT....GEEZ, WHATS NEXT.....PUSHBUTTON PHONES????
TOM
  • Kirksville, MO
Offline Brad-Man
« Reply #15 on: February 08, 2016, 05:15:28 PM »
Doesn't he have an Air Flow Meter (has a spring loaded flapper to measure airflow)
If so he needs to measure the resistance at various points...
  • Marietta, GA
  • '85 K100
'74 RD350
« Reply #16 on: February 08, 2016, 07:50:54 PM »
AFM,MAF, MAS ... it's so confusing.  Yes, he's got the barn door.  It sometimes fails because it's electromechanical in nature; a wiper rubbing against a resistive circuit.  So, dust gets in the way, springy metal stops being springy after 30 years, etc. etc.  There are tests that can be performed which are outlined in Youtube videos.  These same videos also show repairs that can be made in case something isn't right.  If the AFM/MAF/MAS/what-ever-you-want-to-call-it fails to work right, it will upset the fueling and may show up as the symptoms here.
Offline CCalms
« Reply #17 on: February 09, 2016, 01:50:56 PM »
Took the multimeter to my EFI plug today. The resistance from the water temp sensor was correct for the ambient temperature.
  • Seattle
« Reply #18 on: February 09, 2016, 01:55:38 PM »
Hoping this fixes it.  Please keep us posted on how things work out.
Cheers
Offline tsnap
« Reply #19 on: February 09, 2016, 02:35:08 PM »
waiting for a post that says it runs like a striped ape,better than ever,  and that he loves his bike so very much again!!
LOL, thats how it works for me!
tom
  • Kirksville, MO
« Reply #20 on: February 09, 2016, 03:39:06 PM »
Here's hoping it works. :beer:
Offline Brad-Man
« Reply #21 on: February 09, 2016, 04:05:00 PM »
Wonderful news !
Hope that's all it is.
  • Marietta, GA
  • '85 K100
'74 RD350
Offline gpcrane
  • Simian Wrench rides a brick
« Reply #22 on: February 13, 2016, 03:38:57 PM »
I hope the AFM solves your problems.  I too have been having grounding issues.  It was the classic starter motor would not work, the load shedding relay was not pulled in.  So I removed the starter motor and cleaned out 29 years worth of carbon.  I measured the brush length, the shortest one was 10mm, according to my Haynes manual the min. length is 6 mm.  I put everything back together and the bike fires right up, good as ever...until...
As soon as I push the bike off the center stand the engine dies.  I try starting again, the starter motor turns but no ignition.  Back on the center stand and it firers right up.  After a few times going back and forth with the center stand it is running off the stand and I ride a way for a test ride.
The bike feels normal, running great.  I stop for gas, and have no problems starting the bike and coming off the center stand.  I ride for a few more miles and the bike begins to cut out, lights stay on.  Then the bike dies.  Once again it will fire up on the center stand but dies off the stand.  I go back and forth once again and ride it home with no problems.
My first plan of attack with be to clean all around the center stand and check all grounds.  Pull the EFI connector and clean it up real well.  Any other thoughts out there?
Thanks.
  • 87 K 75S 02 R 1150RS
Offline John Lang
  • John Lang
« Reply #23 on: February 13, 2016, 09:18:24 PM »
Is there a side-stand cutout switch on that model? If so, is it somehow shorting out when the bike rolls off the center stand?
  • Ottawa, ON Canada
  • 1987 K75C
Offline gpcrane
« Reply #24 on: February 13, 2016, 09:43:49 PM »
It's an 87 K75 s.  As far as I can tell I do not have the switch, but it sure acts like I do.  After cleaning under the bike and cleaning various connectors the problem is now worse.  I have a hard time getting it to fire up even on the center or side stand.  Once it does start coming off the stand kills it.  Lights stay on and starter motor still works, no ignition.
Thanks, Greg
