Author Topic: Shock adjustment wrench alternatives  (Read 12045 times)
Offline leecow
« on: July 21, 2011, 01:28:49 PM »
Hey folks,
If one wanted to experiment with shock preload settings but did not have the original adjustment wrench, what might be an effective alternate tool? Fairly certain the shock in question is the original.
Lee
'93 K1100RS
Re: Shock adjustment wrench alternatives
« Reply #1 on: July 21, 2011, 01:35:27 PM »
Hey folks,
If it's a stock shock then you could just buy a shock wrench from Ride Worst.  Part # 71112315897.  About $10 or so.
« Reply #2 on: July 21, 2011, 02:59:32 PM »
i gotts an extra you can have... you pick it up when we are in renton wa august 8 thru 12...
Offline leecow
« Reply #3 on: July 21, 2011, 03:50:01 PM »
Thanks Duck and J O. Completely missed seeing the wrench in the fiche.
J O,  I'm backpacking 8/8-10 but can meet up later that week for a burger or somethin'.
Lee
'93 K1100RS
« Reply #4 on: July 21, 2011, 04:05:12 PM »
If you're not backpacking until 8/8 then you should come pay a day visit at the cabin on 8/6.  I can send you home with some extra fresh Dungee too.  The cabin's only about 45 minutes from the Kingston ferry dock.
Offline leecow
« Reply #5 on: July 21, 2011, 07:04:14 PM »
Yep, I plan on making it out for Saturday at least. Might be able to get out Friday night if I play my cards right but that will depend on timing and the ferry line once I can get moving.
Lee
'93 K1100RS
« Reply #6 on: July 21, 2011, 07:15:33 PM »
the ferry line
Just ride up to the front of the line.
Offline leecow
« Reply #7 on: July 21, 2011, 07:30:13 PM »
I knew MC's loaded first but didn't know we could skip right to the toll booth ;)
Lee
'93 K1100RS
awshucks
« Reply #8 on: August 22, 2011, 07:48:37 AM »
Can you post a link for Ride Worst?  My tool kit is missing the wrench you check tranny oil w/.  Thanks!
« Reply #9 on: August 22, 2011, 08:01:17 AM »
http://www.ridewest.com/custompage.asp?pg=hours
The shock wrench for measuring tranny oil only came with the two valve tool kit: part 71112300061
The four valve bikes tool kit came with a separate L-shaped dipstick: part 71112316195
Offline frodef
  • 1986 K75C
« Reply #10 on: August 22, 2011, 09:41:32 AM »
I made my own dip-stick the other day. I found it difficult to get a "reading" off just a metal stick, so I added a bit of black heat-shrink tubing to it which made it much better. Then I added a piece of red heat-shrink offset by 10 mm so as to mark the "max" level. Worked out quite well. Just hope the heat-shrink never falls off into the transmission...  :D
awshucks
« Reply #11 on: August 23, 2011, 10:55:47 PM »
That hook wrench for 2v is NA at: Max, Bob's, and RideWest.  Bob did inform me that a Canadian dealer has them in stock, 5 of them.  Make that 4 now.......................
SM CYCLE ph 250 474 2088...........about $14 plus S&H.
