Author Topic: Austin Texas 85 k100rs build  (Read 104647 times)
Re: Austin Texas 85 k100rs build
« Reply #75 on: January 24, 2016, 07:56:51 PM »
Save the rainforests!
Offline toddlmr
« Reply #76 on: January 25, 2016, 06:07:15 PM »
Got it back together today. It wouldn't start so I pulled the plugs, cleaned them, and made sure wires were on correctly. It fired up and I let it idle for a bit. I was able to get it running good enough to take it to the gas station. It ran pretty rough. I filled it up with 3 gallons of gas. I took it over to the next town (it ran better) and got some fuel cleaner. They didn't have techtron so I bought Seafoam. I put 4 oz in it and ran it toward home with a 10 mile detour. I got back and wanted to fix a few things. The throttle is not very  snappy and seems to bind. I took it apart (Dear lord this is over engineered!) and cleaned up all the  components. Pulling on the cable it is harder effort than I'd expect but it it does snap back. Lubed all back together and it is better but it seems to come back down to idle slow, it will stumble at about 800 rpms, then catch up and idle about 1100. I'm wondering if it is still just problems with dirty injectors? Almost seems like it may have a vacuum leak. Also, when going up a hill or from a stop it seems to spark knock (premature ignition sound) I'm happy to  have it running  and am getting closer!!!!!
  • austin, tx
  • 1985
« Reply #77 on: January 25, 2016, 07:13:16 PM »
Todd BMW tells you not to lubricate the cables but I do. About thirty years ago I was given a sample can of Tri Flow PTFE based lubricant, it is brilliant on cables. You can now get it from bicycle shops.
« Reply #78 on: January 25, 2016, 07:43:33 PM »
Your '85 throttle cable is the earlier design, with the adjuster in the middle of the cable instead of at the throttle perch.  Can you confirm? Stickiness in the throttle can be isolated to either the throttle cable or the throttle tube.  Remove the cable and test the throttle operation.  If the throttle tube rotates freely and with little slop, then turn your attention to the cable.  Make sure it is routed as directly as possible and that there are no severe bends in it.  You might want to replace the original cable with a newer design, with the adjuster at the perch.
Offline toddlmr
« Reply #79 on: January 25, 2016, 08:27:56 PM »
I read tonight about the breather hose and went out and looked at mine... Bad shape. That might be part of my running issue...
  • austin, tx
  • 1985
Offline toddlmr
« Reply #80 on: January 25, 2016, 08:28:30 PM »
There is only an adjuster at the top by throttle assembly.
  • austin, tx
  • 1985
« Reply #81 on: January 25, 2016, 08:32:08 PM »
Ok, so the cable has been replaced with a newer one, good.  Try and isolate the problem to the failing part as I outlined above.  The throttle should be fairly responsive, so sluggishness is a problem.
« Reply #82 on: January 25, 2016, 08:41:23 PM »
Get some self bonding tape and wrap a couple layers around the cracks in the breather hose.  That will tell you if that is the problem, and get you running while you get a new hose.  You will have to take the hose off to wrap it.
« Reply #83 on: January 25, 2016, 08:45:02 PM »
Gryph, Do you think painting the hose with Liquid Electrical Tape would work?
Offline toddlmr
« Reply #84 on: January 25, 2016, 08:51:03 PM »
I got some hose (10 foot) of it.
  • austin, tx
  • 1985
« Reply #85 on: January 25, 2016, 09:42:59 PM »
A couple of things.
If you're talking about the vent hose, sealing the outside won't prove much if the inside diameter has been compromised by material degrading and deposits. As far as a length of hose, it's too difficult to make those bends without restricting air flow. The OEM part with molded bends will work right and doesn't cost much.
Be sure the flange on the throttle grip isn't pushed slightly past the inboard edge of the throttle perch and rubbing on the gear housing. Doesn't take much to slow things down. The throttle should snap back when released.
Offline toddlmr
« Reply #86 on: January 27, 2016, 06:53:41 PM »
A couple of things.
I replaced (well repaired) cracked crankcase breather. It wasn't bad at all, just a small crack. I wrapped it with black tape and am ordering a new one. It does idle a little better. It is still wanting to stall on deceleration. As a matter of fact, it does stall out. I rodw it 45 miles today. Also, it sure does vibrate in the seat. Bars aren't bad. I also noticed it is loud. I don't know why I just noticed but it sounds like it doesn't have much baffle. It backfires on decel through the exhaust. Seems as though no baffle would make it run rough too. (Sounds good). I am thinking about finding a couple vacuum gauges and check on carb sync. I'll post more after dinner.
Thanks!
  • austin, tx
  • 1985
« Reply #87 on: January 27, 2016, 07:15:47 PM »
I thought that putting the red lights in the instrument cluster would have fixed all this; you just never know.
You've raised this thing from the dead, todd, so I'd say it's going pretty good. The idle quirk has been with you from the beginning. You haven't removed the injectors or cleaned the throttle bodies yet, have you? My speed reading isn't at it's peak after 6am. You probably should send out those injectors for cleaning before you balance the throttle bodies seeing as how the whole bike bike was neglected for who-knows-how-long and running fuel that looked like maple syrup probably before that.
Offline toddlmr
« Reply #88 on: January 27, 2016, 07:21:48 PM »
Good point... Can I clean them?
  • austin, tx
  • 1985
« Reply #89 on: January 27, 2016, 07:27:36 PM »
Send them out.
Offline toddlmr
« Reply #90 on: January 27, 2016, 07:29:46 PM »
Send them out.
How much? How long does it take?
  • austin, tx
  • 1985
Offline toddlmr
« Reply #91 on: January 27, 2016, 10:10:58 PM »
I thought about replace intake seals...  man they are expensive...
  • austin, tx
  • 1985
« Reply #92 on: January 27, 2016, 10:30:40 PM »
Have you been traveling this path, todd?
http://www.motobrick.com/index.php?topic=624.0
« Reply #93 on: January 27, 2016, 10:41:40 PM »
they turn them around in less than a day, so time depends on how fast you want to ship.  price is about 20-25 bucks each.  worth it.  they don't just clean, they replace all the plastic bits, put on new orings and test.  i send all my race car injectors there.  been using RC for many years.
Offline toddlmr
« Reply #94 on: January 28, 2016, 11:09:18 AM »
Anyone use these osidetiger.com replacement injectors? They claim to have a better pattern and give better power.
  • austin, tx
  • 1985
« Reply #95 on: January 28, 2016, 11:33:08 AM »
Todd apparently the 4 hole injectors are supposed to be a lot better, off 318I BMW car  or possibly a 4.9 cu in Ford. I have been chasing information. but can't as yet get any solid comparison with proper data. I believe they are available from osidetiger.com.
Regards Martin .
Offline toddlmr
« Reply #96 on: January 28, 2016, 11:37:38 AM »
Regards Martin .
Yes... They are $100 for all 4. Better deal for new.
  • austin, tx
  • 1985
Offline Bill
« Reply #97 on: January 28, 2016, 11:44:52 AM »
In the engine>fuel system there is a thread of one who has done them and likes them ....
I'd link it to you if I could figure out how.
  • Sutton, Ontario, Canada
  • K100 LT
Current:  88 K100 LT
86 K100 R-?L?T parts collection in loose formation...
previous:
84 V45 Sabre
74 CB400
72 CB750
« Reply #98 on: January 28, 2016, 11:45:17 AM »
Todd if you go with osidetiger, could you see if you can find what the exact models these are off, they do not ship to OZ. Have tried a couple of local injector places, and they don't want  know about it, not interested at all.
Offline jakgieger
  • itinerant farmer
« Reply #99 on: January 28, 2016, 12:57:41 PM »
I have used them.  They appear to work well (2500 mi so far).  I am not an expert, but I think that the people at osetiger are qualified :bmwsmile...at least I hope so.
  • Kansas USA
  • 1989 K100rs se
