Author Topic: Austin Texas 85 k100rs build  (Read 104638 times)
Offline toddlmr
Re: Austin Texas 85 k100rs build
« Reply #125 on: January 29, 2016, 05:45:30 PM »
Yeah...
  • austin, tx
  • 1985
« Reply #126 on: January 29, 2016, 06:58:13 PM »
This calls for a dose of Old Tree Hugger, todd.
Offline toddlmr
« Reply #127 on: January 29, 2016, 09:31:49 PM »
Bike is legal! Tomorrow I am gonna ride it to work 28 miles! Leaving at 4:30. Wish me luck! Pica from today. Cleaned, everything installed, mirrors on!
  • austin, tx
  • 1985
Offline toddlmr
« Reply #128 on: January 29, 2016, 09:32:45 PM »
  • austin, tx
  • 1985
« Reply #129 on: January 29, 2016, 09:56:54 PM »
Todd the rear M/Cyl is in a bad spot, very susceptible to water and dirt ingress. I fill under the rubber boot with silicone grease ( I now use the really heavy stuff used on the K75's steering damper ), it helps keep the crap out.
Offline toddlmr
« Reply #130 on: January 29, 2016, 10:36:55 PM »
Thanks for the advice!
  • austin, tx
  • 1985
« Reply #131 on: January 29, 2016, 10:56:10 PM »
Sweet looking ride, Todd.  Good luck on tomorrow's ride!
Offline toddlmr
« Reply #132 on: January 30, 2016, 10:23:07 AM »
Made it!!!
  • austin, tx
  • 1985
« Reply #133 on: January 30, 2016, 10:30:39 AM »
 :2thumbup:
« Reply #134 on: January 30, 2016, 11:39:01 AM »
Bravo!   Those maiden voyages are always a little nerve racking. ...
Offline toddlmr
« Reply #135 on: February 16, 2016, 09:42:52 PM »
Today I rebuilt the master cylinder on the front.I pulled apart the airbox and found the hose for the outlet to air collector had a big hole. I glued it shut (temporary) and it runs a lot better! Idles great. Gonna ride it in tomorrow to work!
  • austin, tx
  • 1985
Offline toddlmr
« Reply #136 on: February 17, 2016, 09:35:17 PM »
I have made  it through my first tank of gas!
  • austin, tx
  • 1985
« Reply #137 on: February 17, 2016, 10:37:32 PM »
Did your bike make it along with you, todd?
Offline toddlmr
« Reply #138 on: February 17, 2016, 10:38:17 PM »
Yes it did
  • austin, tx
  • 1985
« Reply #139 on: February 18, 2016, 09:43:48 AM »
 :2thumbup:
Offline jay1622
« Reply #140 on: February 21, 2016, 01:33:07 PM »
Mine is atleast a year out from it's test fire-up, and I'm alread anxious. Let's see here... What, with wiring, fuel, air, sensitive electrics?
I'm sure every last detail will be dead-on perfect.
 :hehehe
  • Charlotte
« Reply #141 on: February 21, 2016, 01:51:24 PM »
 :hehehe
Will be sweet when you finally get there.
Offline toddlmr
« Reply #142 on: February 24, 2016, 05:07:44 PM »
I've been chasing afront Master cylinder leak. I have taken apart and cleaned the bore, the plunger looks great. I replaced the o ring where the reservoir meets cylinder  and  replaced cover seal. I still have a drip that accumulates on the bolt holding the lever on. I have looked and dont see any other way it could be leaking. Rebuild?
Thanks
  • austin, tx
  • 1985
« Reply #143 on: February 24, 2016, 05:52:15 PM »
Rebuild?
Probably, todd. 😢 Beemer Boneyard has the components but don't rule out divine intervention yet. Give it a day.
Offline toddlmr
« Reply #144 on: February 24, 2016, 07:56:29 PM »
I am missing the big washer on the end...
  • austin, tx
  • 1985
« Reply #145 on: February 24, 2016, 08:55:01 PM »
If it isn't hiding in the bore then you've got a weird market for stolen goods out there. Well, it seems like you're on the right track for repair.
Offline toddlmr
« Reply #146 on: February 25, 2016, 09:03:39 AM »
Found the washer, put it back in place and no more leak! Imagine that!
  • austin, tx
  • 1985
« Reply #147 on: February 25, 2016, 09:32:37 AM »
The wonders never cease here!
