Author Topic: Converting a 1986 Naked K100 To a RT  (Read 12845 times)
Offline Donmystic1
« on: December 30, 2015, 10:52:51 AM »
I have accumulated all the parts that I need to convert my 1986 Naked K100 with 13,000 miles to an RT.
Except for having to lengthen the horn wiring harness and the front signal lights harness everything is bolting up without any glitches.
  • Mystic, CT
  • 1985 K100, 1985 K100RS, 1986 K100RS Turbo,1985 K100RT
Re: Converting a 1986 Naked K100 To a RT
« Reply #1 on: December 30, 2015, 10:58:38 AM »
Nice shop. ..yours?
Offline Donmystic1
« Reply #2 on: December 30, 2015, 11:41:43 AM »
Yes, I have a car lift, air compressor, mc lift, and a parts washer. My wife threatens to move my bed and TV there.
  • Mystic, CT
Offline F14CRAZY
« Reply #3 on: December 30, 2015, 11:56:14 AM »
Finally not an RT being chopped into a "cafe racer"
  • Grand Rapids, MI
  • '87 K75C
« Reply #4 on: December 30, 2015, 12:08:13 PM »
F14, maybe the plan is to build an RT and then chop it up.
« Reply #5 on: December 30, 2015, 02:44:58 PM »
Good one.
Donmystic1, that radiator shroud is a scarce and coveted item (in certain circles). Hope you find a good home for it.
Offline Donmystic1
« Reply #6 on: December 30, 2015, 03:29:44 PM »
I will be selling the windshield, Head light bucket, Mounting bracket, Radiator shroud and side pieces and the rear Tail piece with a luggage bracket.
any interest should call Don @ 860-460-3282 or email at don _ Rich @ sbcglobal.net
  • Mystic, CT
« Reply #7 on: December 30, 2015, 10:11:45 PM »
just noticed you are in mystic. I used to live on flanders rd in stonington and down in GLP.  went to school at that little brick college on the river on north side of goldstar bridge....
Offline Donmystic1
« Reply #8 on: December 31, 2015, 08:06:54 AM »
Flanders road is on of my touring highways in Stonington.
The School North of the Gold Star Bridge is the Coast Guard Academy right?
  • Mystic, CT
« Reply #9 on: December 31, 2015, 09:26:19 AM »
Yep!
« Reply #10 on: January 06, 2016, 07:15:34 PM »
Hi Don,
Over on BMWMOA, I noticed you were asking the same question about adding the RT fairing and observed the same cable length limitation.  One of the suggestions was to purchase wires of different colours to extend the harness, and try to get the same as stock.  Generally, that is a very difficult task to accomplish, but there are a couple of possible creative solutions that will help when extending the wiring, as you've mentioned you need to do.
1) purchase a very cheap harness from eBay to cannibalise.  They are our there.  You can choose one that's been damaged since you're going to cut up anyway for the wires.
2) Introduce the wire splice midway.  For any given wire that you intend to lengthen, clip the original wire partway down from the connector to expose 5" - 6" of wire lead on the connector.  Then strip both ends and solder in the lengthening splice.  The chosen wire can be of any colour but must be of the same gauge.  Use solder and shrink-wrap over each joint.  Try very hard to stagger splices so that the overall thickness of a group of wires remains small.  When finished, wrap up the cable with tape.  This method will mean you always have the correct wire colour at both ends.
Below is the best way to splice wires.
Offline Donmystic1
« Reply #11 on: January 06, 2016, 07:26:55 PM »
I like the idea of purchasing a junk harness on EBay and using the compatible color wires to extend my harness.
I use your techniques to splice the wires.
Thanks again for the input
  • Mystic, CT
« Reply #12 on: January 06, 2016, 11:09:24 PM »
Don,  I have a K75S wiring harness with relay box that I don't need.  Let me know which wires you need and I can check my harness for the correct colors.  If you are interested, make me an offer.  If you like, I can send the whole mess or just the sections you need.
Offline ramnaam
« Reply #13 on: January 15, 2016, 07:35:13 AM »
Good one.
Interesting, I'm converting my K11LT to a naked, I have located the front part of the radiator shroud but missing the side pieces or "wings".
I'm definitely interested in buying!
  • Sweden, Norrköping
  • BMW K1100 Police
Offline Donmystic1
« Reply #14 on: January 15, 2016, 09:02:05 AM »
I may have everything that you need
  • Mystic, CT
Offline ramnaam
« Reply #15 on: January 15, 2016, 10:21:11 AM »
I'll contact you in private message  :euro
  • BMW K1100 Police
Offline Donmystic1
« Reply #16 on: January 15, 2016, 01:11:54 PM »
Hold off I have a local person who wants it. Let me see what happens with him.
Don
  • Mystic, CT
