Gents,
Thanks again for the advice. Got the sync tube caps replaced as well as the crankcase tube with new parts. This did the trick for the rough idle. It runs great now! Working on the throttle problem - cleaned up the springs, etc, on the throttle body but it still sticks so I will follow some of the other suggestions regarding corrosion, the cable, etc. And while it is now running smoothly, it is idling a bit fast so will need to adjust it as some point.
I rode it a bit over the weekend and the rear shock seems pretty weak, so attending to that is on my list now.
Thanks again,
Skids
